Is it possible to get data link to work when you put a Beogram 8002 same with a BeoMaster 7000. The sound runs through a phono stages. What to data link connector pins. Have tried almost everything. Help.
Hello again.
Many thanks for the message I drew how I think you made your
cable. Have not tried the CD input, but I've tried phono input.
Have I made the cable incorrectly.
Cabel pin 6 7 Beogram 8002
6 7 Beomaster
Normal 0 false 21 false false false DA JA X-NONE
the cabel gået fra 6 to 7 and from 7 to 6. My drawing do not work
