Now featuring Apple AirPlay multi-room. Be sure to check the box in settings
Maybe placebo, but I think the sound on Beosound 1 improved (that also got the firmware). Clearer mid/hi range.
Also on A6 I think the sound changed slightly with more treble. I actually had to turn that down in the app.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
The BL3 that are attached to the essence are better
I like that on the essence you can actually select what type of speakers are connected to it.
I also found that by using the Deezer app you can actually select special audio settings and an EQ which made it sound even better
me too realised a slight lack of basses on my A6. i wouldn't give it more bass with the musicplayer's in-app settings for the adverse impacts on the M5 in case of pairing them.
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound + appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
