TX2 dropped needle on moving platter
This post has 3 Replies | 2 Followers
Steve
San Jose, CA
Posts 8
Steve Posted: Fri, Feb 3 2017 11:27 AM
Hello Friends,
I just got a TX2, great table but still learning to use it. I out a EP on, 10" with standard spindle, pressed play and instead of the arm going to start of record, it went to 12" inch position and proceeded to drop on edge of aluminum platter.
Here is the painful part...I had just installed a new SMMC 3 cartridge. I figure the table thought it was a LP because of standard spindle and weight, so lesson learned.
In a complete panic, stopped it...maybe rode on platter edge no more than two seconds and inspected under my microscope uneed high power (old lab scope, 32x magnification).
Diamond needle appears to be OK, no chips, cracks. After cleaning it with brush, the bottom of needle appears OK.
Played a few records and sounds OK.
So my question, has anyone done that ? And by the sounds of it, is my $300 needle OK and I'm just BS paranoid? Or reason for concern?
Thanks,
Steve
Steve
DJ at heart. Vinyl, 8-track, cassette, CD library 10K+ pieces.
Turntables:
1. B&O Beogram TX2 / MMC3
2. Realistic (C.E.C Chuo Denki Co) LAB-420 / Shure m97xe
3. Technics SL-1200 MK2 / Ortofon 2M Blue
4. Realistic (C.E.C. Chuo Denki Co) LAB-450 / Audio Technica AT-95e
5. U-Turn Orbit / Ortofon OM5e
MJBeo
Netherlands
Posts 270
MJBeo replied on Fri, Feb 3 2017 1:21 PM
I would think you would hear it immediately if it was not ok. My MMC4 needle had an "accident" when I was not at home, but it sounded awful since then. I will have to save up and send it to Germany to get it fixed (and upgraded while I am at it).
I hope yours is well!
Beosound 5 Encore + Beosystem 5500 + S45.2; BV7-40 MKV + BL7.1 + BL14.4+ AppleTV4; various link rooms with MCL2 A or MCL2 A/V + RL60.2 / CX100 / CX50 & Cona  / IWS2000; BG4000; Beosystem 1200 + BV1600.
Steve
San Jose, CA
Posts 8
Steve replied on Mon, Feb 6 2017 9:57 PM
Thanks my friend! Yeah, it seems like it's OK. I have looked at it under my microscope (old lab salvage, the microscope, glad I saved it!) under 125x and such and diamond tip looks good, no chipping, cracks etc. Separate issue, the pre-amp I am using sucks...getting a better one, but other than that, I think all is well.
Sorry to hear about your MMC4. Best of luck getting it fixed!
Cheers,
Steve
Steve
Turntables:
MJBeo
Netherlands
Posts 270
MJBeo replied on Fri, Feb 17 2017 10:45 AM
Steve:
Glad to hear! What kind of pre-amp are you having, and what kind are you getting? I might want to connect a BG4000 in one of my link rooms, so I also will be looking for a good pre-amp to do right by it. I see many of these kind of amps, very affordable, and also more vintage models, but I do not know it they are any good.
Page 1 of 1 (4 items) | RSS
