Monitor not working properly on BLGW/KNX
This post has 0 Replies | 0 Followers
athos
Posts 46
athos Posted: Fri, Feb 3 2017 9:06 PM
I using the BLGW for a longer time and found out that the monitoring part does not work properly any more. In the past I could see when I pressed i.e. a keypad button for my light, the exact address of the connected dimmer (like 0/3/5)
Now I only get info in the monitor path of already designated resources, also when I press the keypad which execute a command which is already a macro in the BLGW. Without the actual adres. So the monitor does gets info from the system. When I press a button for a cation which is not designated with a macro or resource, I don't get any reaction. I am quite sure it worked in the past. Anybody any idea?
Page 1 of 1 (1 items) | RSS
