BV 7-40 Floor stand on BV 4-42
Peter
Sweden
Posts 84
Peter Posted: Sat, Feb 4 2017 10:38 AM
HI All,
Is it possible to use the motorized floor stand from a BV 7-40 on a BV 4-42 or BV 4-50?
As far as I know there is no outlet on the beosystem 3 for motorized stands, am I correct?
But is it at all possible to mount the screen at all?
Peter
Beovision 7-40 Mk VI, Beovision 3-32, Beovision AV9000, Beovision AV5, Beolab 8000, 6000, 5000, 3000, 2000,  Beocenter 2300, 9000, Beocenter 2, DVD1, DVD2, Beogram 3300, LC2, Beolit 12, 3 x AppleTV
Beovision7
Derby
Posts 10
Hi, I also want to find out if you can connect a beosystem 3 with a BV-40 stand.
Can anyone help or advise please, I see the Beosystem 4 has a connection for stand but no connection on the BS 3, but the BS 3 still has all the stand calibration software?
Rob - Danish AV
Melbourne
Posts 376
It’s just a small cable that simply plugs into the inside of the bsys3
bv4 will not fit, would need to find an STB bracket
Beovision7
Derby
Posts 10
Thanks, I will get one from my dealer :-)
Beovision7
Derby
Posts 10
I got the cable today for a BS3 to BV9 but can't find which board in the BS3 the cable plugs into :-(
Can anyone please help pinpoint the location.
Thanks in advance
Denboef
Posts 10
Denboef replied on Wed, Oct 28 2020 2:18 PM
Hello,
From the Hague Holland!
I have here a Beosystem 3 with Beovision 7 floorstand. Can you help me to connect them? Do you have a article-number or link where I can order this special cable?
Kind regards, Hilbert
Page 1 of 1 (6 items) | RSS
