It could be because the h6 cable has the output for the microphone. So it has 4 outputs instead of 3 which sometimes do not play nice with a plug that has 3 terminals. You could try and take the headphone plug out of the converter by a few millimeters and see if that gets the correct sounds.
delroy: It could be because the h6 cable has the output for the microphone. So it has 4 outputs instead of 3 which sometimes do not play nice with a plug that has 3 terminals. You could try and take the headphone plug out of the converter by a few millimeters and see if that gets the correct sounds.
The H3 is the same way and I've literally never experienced problems with mine because of that. I regularly plug them into jacks that don't have the 4th contact, both 3,5 and 6,3 mm (such as the one in my MOTU UltraLite Mk3 audio interface).
My suggestion is to try a different adapter, those can be flaky sometimes.
— Tuomas | Bang & Olufsen | Bang & Olufsen Create
have fun.... I really enjoy the sound reproduction through my B&O headphones and there are some great Apps and Amps out there where.
