When keyboard doesn't light up on Beo5/6..
Weebyx
Denmark
Posts 1,213
Weebyx Posted: Tue, Feb 7 2017 6:22 PM
My Beo6 which I had brought back to life, suddenly stopped turning on the keyboard light.
Nothing could get it to turn on, dark room, reboot, new configuration, battery disconnect.
But while I had the keyboard out to disconnect battery, I noticed that the flat cable going to the screen from keyboard, was very bend, and looked like there was a bad connection at the side of the bend.
By totally luck and chance, I actually had a cable in the drawer, (once got a bunch of different cables while trying to fix a BL5000 screen). The cable is the same, but a bit shorter, but that was no problem.
Removed the screen and changed the cable.. Keyboard light back on :)
/Weebyx
TWG
Posts 1,672
TWG replied on Wed, Feb 8 2017 6:10 AM
sometimes you just need some luck... :-) Re-Enjoy your Beo 6.
Page 1 of 1 (2 items) | RSS
DigiCert Secured Site Seal
