Beolight LC2 stopped working
jviala
Posts 2
jviala Posted: Thu, Feb 9 2017 2:49 PM
Dear B&O users,
668/5000
Since 3 days my 3 beolight LC2 no longer work. I can only activate 2 of them by hand.The third turns on with the Beo4 and then turns off alone after 1 hour of operation. I can turn it back on again and then it goes off after about 30 minutes of operation. The most surprising is that at night it lights up alone at least twice!
I also have a LC1 beolight that only works manually (since the same day) it no longer responds to my Beo4 remote. I can not adjust the height of the light: it is only 100% or 0%.
A user posted the same type of problem in 2014. After a few days everything would have returned to order.
Have you had this kind of problem ?. I'm worried about whether everything will go well as before. Thank you
cordially
MADSYSTEMES ZANUSO
Paris
Posts 29
hi
the lc2 can be repair, contact local service center
if you are in Paris, contact Mad service center http://www.bang-olufsen-sav.com
Regards
Mr ZANUSO
Page 1 of 1 (2 items) | RSS
