My Beolab Penta's (questions and restoration thread)
This post has 14 Replies | 2 Followers
Beitie
Minnesota, USA
Posts 63
Beitie Posted: Fri, Feb 10 2017 8:15 PM
So I know I've been kind of all over the place here, but I'm really enjoying the Bang & Olufsen lifestyle and vintage products. So I took a plunge and bought a pair of Beolab Penta 1 speakers (6603). I knew they would have some of the usual issues. Rotted surrounds on the mids, and an amp supposedly has an issue as well.
My goal with this thread will be to document the repairs as best as I can, and also to ask questions of others who have done similar restorations. This pair of Penta's are far from perfect, so it will be a bit of a process for me, and I don't expect it to go too quickly.
A little background information first. I bought these from the original owner. He stated right away that one of the amps had an issue for sure, and he wasn't sure about the other since he was using them with a different amplifier all together. He also stated that he didn't know how to remove the grills, so he was unable to check the rot condition of the mid range drivers.
After unpacking everything, I checked to see what I all had. Speaker towers, check. Beolab 150 amps, check. Speaker stands, check. Hardware to secure them all together... Nope, dang. Oh well, that's pretty easy to find, but it would be nice to confirm the size of bolts that I need. I think according to the service manual, it's a 3.5 x 50mm (page 4-4).
So, after a few emails to Peter, talking about the speakers. I then sent an email to Martin asking about his amp and crossover refresh kit. He asked for a few pictures of the crossovers since there can be a few different styles. So I dug into the speakers, and found a mess! The crossovers have been worked on previously for sure since one board in each tower had tape over the sides, and some weren't even in the proper grooves inside the tower.
I also found coils that have fallen off the board. On one of the boards, the magnets that go around two of the coils were shattered and the pieces were laying inside the towers. This could have been due to shipping, but I'm now going to have to figure out what to do with them.
Notice the broken magnets around the coils here:
So my questions are as follows:
1) Do I need to replace the coils that have come loose? Or do I just re glue them to the board?
2) Are there replacement coils for the ones with the broken magnets?
3) Should I go with the foam surrounds? Or the rubber ones?
4) Any ideas on how to un crush the dust caps on the woofers?
Beitie
Minnesota, USA
Posts 63
Beitie replied on Sun, Feb 19 2017 5:43 PM
So after a few emails to Martin, I've found that this is a very early model. Also, I was incorrect, the broken pieces of the crossover are not magnets.
So it looks like my best options are to find other sets of crossovers. Unless anyone knows how to get new parts for these?
priklep
Slovakia
Posts 103
priklep replied on Mon, Feb 20 2017 9:00 AM
Hi Andrew,
ask Martin (Dillen) again.
priklep
Slovakia
Posts 103
He probably could source parts for Penta's. He is located in DK.
Weebyx
Denmark
Posts 1,213
Weebyx replied on Mon, Feb 20 2017 10:06 AM
The hardware to secure the amplifiers and feet to the base, are much longer than 5cm...
You can see them here.
The first are secured to the speaker, then you slide the amp along it, and again under that, you attach the feet and secure the 3 parts with bolts.
http://www.ebay.ie/itm/5x-Bang-Olufsen-Beolab-Penta-Screws-Bolt-Rod-Threaded-/181511810408
Each penta needs 5 pieces.
I have used foam surrounds in the ones I have restored.
Regarding your loose coils, I would try to glue them back on, and the plastik bits that came of, true also with glue.
You can just connect both speakers to an external amp and run them as passive Pentas, just to see if they work.
I have uncrushed a cone just using a bit of sticky tape, press it "hard" where the crunch is, and then pull back quick, it solved it for me.
Beitie
Minnesota, USA
Posts 63
Beitie replied on Mon, Feb 20 2017 1:51 PM
Weebyx:
Oh, this is very helpful. I did not know that the screws would be double side threaded rods. Very nice to find this out! Thank you for all the information, and I will try all these tips out. Though instead of buying the rods for $60.56 on eBay, I'll try to see if I can get them from a local fastener company. I'll just have to find out the proper length and thread size. The thread size will be easy since I have the nuts from inside the speaker cabinet. Length might be a little tricky.
Beitie
Minnesota, USA
Posts 63
Beitie replied on Mon, Feb 20 2017 1:53 PM
priklep:
Thank you! I have been in contact with him, and plan on purchasing the amp kit for sure.
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Fri, Feb 24 2017 10:45 PM
Andrew:
I usually use a vacuum cleaner to pull them back out.
Beitie
Minnesota, USA
Posts 63
Beitie replied on Fri, Feb 24 2017 11:01 PM
I did try my little shop vac, and it wasn't powerful enough. I'm scared to try my Dyson. I have watched a few YouTube vids on this subject and also the tape idea from earlier, so I'll look into those first.
GregKo
NYC
Posts 25
GregKo replied on Fri, Feb 24 2017 11:51 PM
Hi Andrew - I recently restored a set of Pentas (2's) and commend you for giving it a go.
Regarding the dust caps - It's pretty much a cosmetic issue that doesn't effect the sound, but in the pursuit of "perfection" there are a couple of options.
Obviously the right way to do it is to remove the cap and order and install new ones - I've done this and is by far less effort than reforming the midrange surrounds (that's a messy job).
For a quick fix, however, simply bend the tip of a long thin needle into a curved shape, pierce the dust cap (often in a few places) and carefully pull it back out.  That should work fine to restore them aesthetically and all you really need to do after that is fill the holes you made - A dap of contact cement, thick cyanoacrylate glue (superglue, crazy glue, etc.) will do the job.
Keep us posted on your progress!
Take care
Greg
Beocenter 9500, Beomaster 6500, Beolab Penta MKII, Beolab 5000, Beolab 3000, Beolab 4000 MKI, Beolab 4000 MKII, Beogram 3300, Beogram 3000, 2X Beolink 7000 RDS, 2X MCP 6500
Beitie
Minnesota, USA
Posts 63
Beitie replied on Sun, Mar 12 2017 6:10 PM
So I was able to spend a little time on these yesterday. First I tried to use a Q-Tip and glue method to un-dent the dust caps, but I proved to not have the proper patience for it. I also tried the cardboard tube and suck method, but I proved to not have enough suction for that. I wanted to save the pin method as a last resort, because I knew it would leave a small hole, so I went back to the Shop Vac method. This time with a much bigger and more powerful Shop Vac. This worked! I had to use two fingers to steady the cone, while the vac sucked on the dust cap. It's not perfect, but it's MUCH better than it was.
I also can say that the B&O Type number is: 6603, even though I know that's not a huge thing, I just wanted to have that down in this thread for my own and others reference.
I spent a little time with the Ferrite Cores, I wanted to see if I could puzzle piece them together. I was unable to figure them out... but I'm still hopeful. Also, I've found that you can find similar items on Amazon. I'm wondering if this would be something worth while to look into? I'd sure love to get this part figured out so that I can continue on with the restoration.
Beitie
Minnesota, USA
Posts 63
Beitie replied on Sat, May 13 2017 6:31 PM
So it's well past time for an update here. After only a few months of waiting, a set of crossovers from a Penta III came up for sale on eBay. I took some time to think about it, and eventually I decided I would give them a try. I was warned that they may not sound correct, but I was sick of waiting, so I took the plunge. Plus the price was decent when compared to other things I was finding.
While these are for sure an updated version of the crossovers from my Penta I's, the wiring was the exact same, and the only difference I could find was that the two boards were soldered together instead of having individual leads that went to the speaker posts.
Once I had the 'new' used set of crossovers in, I could finally test the drivers and amps. I found that two of the woofers that had crushed dust caps would rattle, but everything else seemed to work just fine. Overall, I thought the sound was very good. I was surely not disappointed.
The same seller that sold me the crossovers also sold me a full set of woofers, the long mounting rods, and other hardware I would need to set these up. So once I had the woofers set, I set up the speakers and amps to their base, and hooked it up to my Beocenter 9000!
Finally it was all alive! The amps worked, the speakers worked, and I was making some real progress :) I even found a much better stand for the Beocenter, Beogram, and 8 Track player.
There is still a lot more to do. I've been trying to sell my Beosystem 5500 items, and still have the MCP and the Beomaster left, up for sale together on eBay. Once they sell, and I finally have access to my funds, I'll be looking at getting the supplies for replacing the surrounds on the mid range drivers. Also, I'm hoping to get a recap kit for the crossovers, and an amp kit from Martin.
So far they are actually sounding very nice in this system, and I'm very happy with them. I'm hoping that fixing the bad parts only makes them better :)
Saint Beogrowler
Saint Paul
Posts 780
What kind of 8track deck is that?
Jeff-Piaf posted about 8 track repair a little while back using these
http://www.katestrackshack.com/suppliesforsale.htm
And had a good experience.
Yeah analog.
Beitie
Minnesota, USA
Posts 63
Beitie replied on Tue, May 16 2017 2:40 PM
The 8 Track player is a Pioneer H-R99 that I bought back in 2002 :)
That website might be one I'll have to visit. The foam pads are a real concern on most of my 8 Track carts, but I don't have a lot.
A fun video featuring a very similar Pioneer H-R99 8 Track player was done not too long ago by Techmoan, his YouTube channel is a seriously fun watch. Always something interesting that he's playing around with.
Watch the Techmoan vid here.
Over the weekend, I did have the Pentas on for a longer listen, at fairly low volume. Mostly used as background music for Mothers Day meal. I did notice that one amp turned off after a while. I think the LED was a bit more of an orange/amber instead of red/green. So that is something that will have to be looked into when it comes to service time. I think that might also be what is going on, a few times I've turned on the system, and that same speaker would not switch on. Fun stuff :)
Beitie
Minnesota, USA
Posts 63
Beitie replied on Thu, Sep 14 2017 2:36 PM
So just to keep this thread updated, and mostly complete. I gave the Penta's to a member here on Beoworld to have the mid range drivers re surrounded, the amp kit from Martin was done, and the crossovers fully re capped. There are still a few visual defects with the Penta's, but overall I'm pretty happy with them. I've been playing around with room placement and trying to find some good spots for them, and listening. These speakers can sure throw some serious sound out! It's pretty fun.
I did decide to go with the rubber surrounds for the mid range drivers. I just feel it fits the overall design a little better, and will last longer, and I plan on having these for a very long time. I also re glued on all the trim pieces. In hindsight, I wish I would have just used the grills to keep pressure on the trim. The tape worked well, but one of the trims didn't get set fully flush, and the grill just barely makes it onto the cabinet.
Grills on:
Newest room arrangement:
Page 1 of 1 (15 items) | RSS
