Need some assistance here gents. I purchased a 3200 for peanuts at a local pawn shop. The only issue is the guide wire for the magic doors is off track. The sensor picks up hand movement and actuates the door motor. I looked at the shop manual and it did not give details of the routing. If anyone has pictures or can direct me to a diagram detailing how it is stung up it would be greatly appreciated.
This may be useful in conjunction with the service manual.
http://archivedarchivedforum2.beoworld.org/forums/p/28135/231267.aspx#231267
Or this: http://archivedforum2.beoworld.org/forums/p/3813/34171.aspx#34171
Fantastic!! This is a start. Thanks U Sir
No problem! I did the process on my BC2300 a while back and it's a bit fiddly, but very satisfying when it works! Good luck!
