Background noise in movies?
This post has 20 Replies | 2 Followers
steve1977
Posts 911
steve1977 Posted: Sat, Feb 11 2017 5:35 AM
i have a BV7 connected to 4 BL8002 and a BL2.
playing music is fantastic. i love the BL8002 for that.
Movies in 5.1 are a bit weird. on the one hand, the BL2 really comes in for action movies and is fantastic. however, there is something about dialogue scenes, where background noise from the movie (leafs flying, wind, paper moving) is output disproportionally loud. on the one hand, this is great as these are part of the audio track that i wouldn't even notice on other TVs. on the other hand, it is too loud and distracting from dialogue scenes.
anyone has made a similar experience and are there settings to control / tune that?
Chris Townsend
Qatar
Posts 3,531
Yes, I still struggle to hear dialogue on my 7-55 with a 7-6 although it's better than the 7-2/8000 combo.
Constantly had volume over 70 just to hear what's being said, then BANG....a door shuts!
Never have this problem on our Avant RF or the 5-42. The only solution found was to tell the Tv the centre speaker is miles away so it artificially enhances the volume. Crap system.
Seanie_230
UK
Posts 2,278
Wow my 7-55 with 7-4, BL9 & BL6000 is amazing
The clarity is perfect and I never have an issue.
Perhaps you need a detailed centre speaker in fact I'm sure of it. Centre is where the vocals etc go normally.
SK
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Sandyb
Posts 2,186
Sandyb replied on Sat, Feb 11 2017 1:27 PM
I can occasionally have the same with my BV12-65 (with BL18s front, BL19 and BL3s rears).....though it does vary by source ...very action heavy soundtracks especially.....might be to do with the way the tracks are mixed....regular talkie films are fine and don't suffer.......even for action films, if I add one meter to the centre speaker distance setting, all is fine, so no big stress in the end......
Chris Townsend
Qatar
Posts 3,531
Seanie_230:
SK BLGW - Rekindling the love of ML
When I had the 7-40 it had a 7-4 and it was the worst of the bunchErm.. YouTube is often better as a source, but like I said this just isn't a problem for the legacy TVs. If I had to pick any Beovision to listen to what's being said, I'd pick an Avant RF.
I think Jeff changed from the 7-6 to the modern Avant, and his first hand experience was that it was better. Not sure if that included the vocals.
Seanie_230
UK
Posts 2,278
Hay Chris
Wow I suppose sound is specific to each listener.
This is why home demo's for a few days in all scenarios are so important.
I am going to buy either a used or new avant this year from a dealer or 2nd hand source.
I think I must have a demo TV in my home for a week to make 100% sure I get on with it as when I purchased speakers I went through three models.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, Feb 11 2017 2:27 PM
I center channel speaker is important, about 70% of the sound comes out of the center channel. Unfortunately, too many movies and shows are poorly mixed and the center channel volume is not high enough to bring out the dialog. I found "Interstellar" to be one of these, I had to up the volume of the center channel significantly to be able to make out the dialog in the presence of overly loud L and R effects. If your TV/processor allows this, jack up the center channel volume. Even if it is setup to use only L and R and  "phantom" center you should be able to increase the amount of center sound sent to the L and R by upping the volume of the center.
It's very annoying to not be able to hear dialog. Recently I encountered that watching "The Expanse" on Amazon Video. Fortunately it's fairly easy to go into the menu and play with volume settings on my Marantz AVR.
Jeff
leosgonewild
Helsinki, Finland
Posts 2,373
Just to check, can you try to choose speaker 5?
I had the same issue with my setup once, and for some reason it turned itself to speaker 4, so the center channel was actually missing..
olvisab
Posts 1,391
olvisab replied on Sat, Feb 11 2017 7:04 PM
I said it maybe ten times on this forum. On a 5.1 set up the only way to increase the sound of the center channel is by lowering the level of the front speakers.
I never add any issue with my several bv7.
There are real differences if you select speaker 5 instead of speaker 3 when you have only 3 speakers and a 5.1 source.
If you have only a 7.2 or 7.6 and your movie is in 5.1, your bluray player should be able to downmix the output in stereo.
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
olvisab
Posts 1,391
olvisab replied on Sat, Feb 11 2017 7:05 PM
steve1977
Posts 911
steve1977 replied on Sun, Feb 12 2017 3:04 AM
leogoeswild:
Thanks for your quick replies.
Center speaker is working.
Actually, stereo sources play very well in 5+1 and i don't have this issue.
it only happens on 5.1/dts sources. it's about the balance. dialogue is fine, but the "background noise" is annoying.
both center and two fronts are set to 4m, which is about right for my viewing distance. can increase it a bit. you suggesting to increase the center speaker more than the fronts?
leosgonewild
Helsinki, Finland
Posts 2,373
And you have done the other adjustment where you adjust the sound level?
olvisab
Posts 1,391
olvisab replied on Sun, Feb 12 2017 12:14 PM
You can set the distance and the level of the speakers. Reduce the level of the front and the center speaker will be louder.
steve1977
Posts 911
steve1977 replied on Sat, Jun 30 2018 4:06 AM
I am pulling up a very old thread as the issue remains for me.
Speaker mode 1 and 2 are brilliant. But I have a 5.1 audio system (BV7 with 4 x BL8000, 1 BL2), so would love speaker mode 5 to work as well.
I reduced the speaker level of the two front speakers by 8 "ticks" which makes it better. I doubt that this is meant to be like this?
Can anyone post settings for levels?
elephant
AU
Posts 8,219
elephant replied on Sat, Jun 30 2018 6:22 AM
Steve my family of BV8s are old tech
Here are my current settings
Which I would like to changed based on 2017 thread comments ... but I have no discrete centre speaker volume ???
Or maybe everything is relative to the (invisible) centre speaker; so I am going to try the following !!
BeoNut since '75
steve1977
Posts 911
steve1977 replied on Sat, Jun 30 2018 7:01 AM
Why is your default speaker set to 2 and not to 5? with my basic understanding default speaker set 2 runs the front speakers in stereo, but turns off the center speaker and reaers.
Sandyb
Posts 2,186
Sandyb replied on Sat, Jun 30 2018 8:01 AM
This is an issue more broadly though, and i agree its not ideal.
Look around on AV sites, and you will see that the sound mix on many discs causes many many people to struggle with the vocals. And it has become fairly common to hear of people using subtitles with native language content, which is just odd when you think about it.
Hence you have newer sound-bars with vocal boosting / speech clarifying modes. I think those modes have to be quite aggressive to get to a sensible result.
For my 5.1 set up (BV12-65 as centre, BL18's s fronts, BL19 sub, BL3s as rears) i have had to exaggerate the speaker settings quite a lot to get to a better understanding of the vocals. And whatever settings parameters work well for one movie, don't always work for the next disc.
elephant
AU
Posts 8,219
elephant replied on Sat, Jun 30 2018 8:25 AM
steve1977:
Your understanding is correct.
I chose those defaults for stereo music, and for video to have a broadcast default of no subwoofer
I prefer full on 5.1 —- other family members don’t.
So when I can I slip [speaker][5] on and hope no one notices Big Smile
BeoNut since '75
steve1977
Posts 911
steve1977 replied on Sat, Jun 30 2018 8:45 AM
Sandyb:
Very interesting.
Why is this not an issue with my crappy tv-internal speakers (e.g., with my sony)? also, not an issue if i connect my A9 over line-out to my sony.
I tried bv7 center speaker only again and - much to my surprise - the voice is less audible than with my sony internal speakers. i must be missing something obvious?
Sandyb
Posts 2,186
Sandyb replied on Sat, Jun 30 2018 9:11 AM
Yeah, dont know the answer properly, beyond speculation.
But its a general industry issue i believe.
The problem it poses is this : it makes it a little trickier having a speaker / audio setup that works very well for both music and video i.e. the integrated setup. The inaudible speech issue is only part of this broader problem, the other being the changing surround formats, and their delivery (optical, HDMI, 1.4 vs 2.0 vs 2.1)
I'm not surprised that high end audio brands like Linn, Naim, (and Meridian to a degree) have emphasised 2 channel stereo much more in the last few years. Their setups are great for music, but might not tick every box on video surround.
And at the other end, look at the new Sonos Beam, which emphasises speech. Made for video, but not very good for music (according to some reviews)
Anyway, off topic a little - but just reminds me that finding a set up that is highly capable with both music and video is not getting easier.
steve1977
Posts 911
steve1977 replied on Sat, Jun 30 2018 10:23 AM
I would be fine to let the 5.1 go. Currently, movies are better to watch with my Sony with crappy in-TV speakers than with my BV7 with BL surround setup. This obviously makes no sense. I can always put the BL in different use elsewhere, so I am fine to go change to a 1.0, 1.1, 2.0 or 2.1 setup. This would all be stereo setups? However, I am not sure how to best set this up in the BV menus and the ATV menus. Any thoughts? Would this solve the voice issue and get me superior quality to my Sony. If so, I could even move one pair of BL and connect it to my Sony instead?
Page 1 of 1 (21 items) | RSS
