I cannot reset Beocom 2 phone after all
flipper62
Posts 50
flipper62 Posted: Tue, Feb 14 2017 11:35 PM
Hello,
After reading the instructions to reset my second hand beocom 2 phone, it still won't do it.
0) Phone shows:no contact with base
1) to get in the reset menu: 9#9#9* (HOLD or INT)
2) First mentioned on display: HS SW. Ver.  push OK --> I get a number which isn't the one on the PSTN
3) next: reset the PSTN on the back and tried power off/on
3) Scroll down in the reset menu phone, but no reset option mentioned, only telephone details.
4) PSTN is OK. My other beocom 2 works fine.
I just noticed. The handset is not keeping any settings (like: time/date) after power off (or are these stored in the PSTN base?)
Anyone who can help me. Did I forget something or is there another method?
Your help is appreciated.
Ralf
Hamburg Germany
Posts 189
Ralf replied on Wed, Feb 15 2017 9:39 AM
is this a new Beocom 2 that you want to connect to your existing base?
Some early Beocoms 2 came with their own base and only could connect to these kind of bases. (built in the charger base).
But you can update the software , so that you can connect to any kind of base like PSTN from Beocom 6000 or Beocom 5.
If your Beocom 2 charger has an additional telephone cord, this could be the issue.
Can you post the production date and HS SW?
Ralf
flipper62
Posts 50
flipper62 replied on Wed, Feb 15 2017 12:03 PM
Hello Ralf,
You're correct
I talked to a dealer and he told me same.
The charger was not included.
HS SW: 0031-1.5-1   200111071230
product date: 280202
Can you do this?
Regards,
Richard
Ralf
Hamburg Germany
Posts 189
Ralf replied on Wed, Feb 15 2017 3:12 PM
Hi Richard,
no i can't!
Only the dealer has the special setuptool needed.
I was only charged with 20 Euros, and i could wait for it. So it is only little thing.
Ralf
flipper62
Posts 50
flipper62 replied on Wed, Feb 15 2017 3:53 PM
Hello Ralf,
Thank you very much. Tomorrow i'll visit the dealer. He charges me 25 euro.
Regards,
Richard
flipper62
Posts 50
flipper62 replied on Thu, Feb 23 2017 7:00 PM
Hello Ralf,
I came back from the dealer. They couldn't upgrade the phone,to version 2, only  the original software.
Any ideas?
Regards,
Richard
Page 1 of 1 (6 items) | RSS
DigiCert Secured Site Seal
