I need help with working around a networking issue. My A8 network card seems to be broken. I can't connect even with a cable to my router. The cost of fixing this is about €300, so I've been told instead that I can connect it to airport express and this way work around the network card. Can anyone help with how to set this up? i.e. how would streaming work then?
Thanks,
D.
Agree - the CCA works well with the BS8/A8.
But - if you prefer using AirPlay - the APE should do the trick as well.
