Essence remote and BV14
This post has 6 Replies | 2 Followers
Chris Hassell
London
Posts 396
Chris Hassell Posted: Tue, Feb 21 2017 11:51 PM
Does anyone know if it's possible to pair an Essence Remote to a BV14?
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
BeoMegaMan
Posts 601
Yes you can but with limited functionality currently
Ah, you know... A little B&O here, a little there
kuyttendaele
Posts 707
BeoMegaMan:
Serious? Please describe "limited functionality"
I contacted BeoCare and they replied that they are not compatible... and that to wait for the next firmware update of the BV14 and the release of the new Remote app.
Would love to have the Essence remote on my desk controlling the volume of my BV14
Karel.
Chris Hassell
London
Posts 396
kuyttendaele:
Karel.
Me too. Ideally it should work as it does with the Essence!
BeoMegaMan
Posts 601
If I recall correctly currently you can turn on the TV and control volume, but that's about it. Currently the functionality isn't there for practical use, but it will technically connect and work a few functions.
kuyttendaele
Posts 707
Volume is more then enough for me! If more functions work.. that's fine.. but volume is the main reason why I would add an Essence remote. Turning it off would be fine too... But most of all just volume.
Karel
Chris Hassell
London
Posts 396
kuyttendaele:
Karel
Completely agree
Page 1 of 1 (7 items) | RSS
