Beolab 5 with software vs 2.6.
Pressing the top button, the mic extends, but the calibration doesn't start. After a few seconds, the mic retracts and the speaker blinks red. I have to press and hold to stop the red blinking.
Any ideas how i can fix this?
There is apparently a maximum number of calibrations for each BL5 which is cleared with a SW reset. Perhaps that is the case with your speakers?
Here's the thread which describes what you seem to be experiencing:
http://archivedforum2.beoworld.org/forums/p/21485/177311.aspx#177311
Thanks. How do i reinstall the software? Doesnt say in the manual...
Cabinet change did the trick
