Beogram 1500 series 1
This post has 3 Replies | 0 Followers
Martyd_d
Posts 2
Martyd_d Posted: Tue, Feb 28 2017 7:10 PM
hi I've inherited a beogram 1500 series 1 and everything seems to work fine except the sound comes out very low even when Turned right the way up and if you touch any of the metal switches it buzzes like mad any ideas would be gratefully received
beo3000
Posts 109
beo3000 replied on Thu, Mar 2 2017 2:46 AM
the amp inside it is very low power, so if you have inefficient speaker that could be the cause
Martyd_d
Posts 2
Thanks for reply, the speakers are the b & o speakers that came with th the unit
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Mar 3 2017 11:54 AM
Sounds like either a bad pickup cartridge, bad RIAA, bad power supply or a grounding issue.
Perhaps a combination.
I would check the power supply first.
Page 1 of 1 (4 items) | RSS
