Beovox S45.2
This post has 46 Replies | 0 Followers
Craig
Yarm, United Kingdom
Posts 2,040
Silver Member
I carefully replaced the magnet base plate and core back into the magnet and frame assembly, it promptly wedged the sound coil between core and frame of course, then fitted the "jig" in place. Tightened the inboard screws to hold the jig to the magnet and frame first, making sure it was firmly in place, and then tightened the outboard screws finger tight.
Craig
Posts 2,040
Silver Member
Craig replied on Sat, Jan 13 2018 4:38 PM
With the dust cap picked away from the cone and holding the speaker in one hand it was a really easy task to adjust the screws whilst looking at the position of the core in the coil, I was able to centre it by eye very quickly and pushing on the cone confirmed that I had no scraping or binding of any kind....applied liberal amounts of epoxy and it is now drying on the worktop, looks a bit like something "Johnny Rotten" may have worn around his neck back in the seventies I know.....but such a good result. Anyone needing to repair a woofer just drop me a line and I will post it off (just dont forget where it lives ;~)
Craig
Craig
Posts 2,040
Silver Member
and a pic
Søren Mexico
Mexico City
Posts 6,411
Compliments, I tried the same on a M70 woofer, the base plate slipped on inserting and destroyed the voice coil
Craig
Posts 2,040
Silver Member
Craig replied on Sat, Jan 13 2018 5:40 PM
I can see that happening, you need to be very careful putting the core back into the coil...they are quite fragile
MrRoast
Posts 340
MrRoast replied on Sat, Jan 13 2018 7:42 PM
I definitely need to epoxy the magnets on my S45s as future-proofing!
DMacri
United States
Posts 881
DMacri replied on Sat, Sep 15 2018 12:50 PM
I used epoxy on both of my S45 speakers to prevent future mishaps.
I have to replace those rusted screws!
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Page 2 of 2 (47 items) < Previous 1 2 | RSS
