Hi! I'm getting a Beomaster 4500 and I'd like to get some speakers for it. Would the Beovox 4500s make a good combination? How about the Beovox RL2000? Any other suggestions?
Thanks!
Beolab 4500s are even better and if you want passive, you cannot go wrong with S45.2s on stands or wall brackets (the latter are tricky to find!)
Peter
Thanks for your answer!
Well I actually got a great deal on a pair of Beovox 4500s... I won't be disappointed, will I?
By S45.2s you mean these? Type 6312?
https://www.beoworld.org/prod_details.asp?pid=666
I may try to connect all four speakers :)
