Beosound 5 Encore and WD MyCloud NAS dnla
This post has 11 Replies | 3 Followers
Clinton
Posts 5
Clinton Posted: Wed, Mar 1 2017 8:03 PM
my Encore does not see the N/Music on my new WD MyCloud.
The Beovision 11 does accept it.
can anyone help?
thanks
Detlev
Damian2874
Posts 4
Damian2874 replied on Thu, Mar 23 2017 11:35 PM
Hi Detlev, I'm having the same issues, did you get it fixed? If so how? Thanks in advance
Clinton
Posts 5
Clinton replied on Sat, Mar 25 2017 8:03 AM
hi Damien,
apparently the beosound does not work with all NAS software protocols.
finally I used an external hard drive, but there were also some issues.
u need an usb drive with separate power supply, because the usb connection does not provide enough power to use 2.5" hard drives.
the beosound did  read a  2.5" hard drives with external power supply, but had software crashes several times.
now a have 3.5" drive from WD and until now (3 days) no crash.
hope that helped a bit
Detlev
Aussie Michael
Melbourne, AU
Posts 3,730
Hi
I used to have an encore and I used it with a WD MyCloud NAS Drive
I had the same issue , but you have to rescan on the Encore
You have to get in to the service menu to do this
I was also given a pretty good user guide by B&O dealer which covers a few other things - PM me your email and I can scan a copy and send through
Cheers
Michael
Clinton
Posts 5
Clinton replied on Sun, Mar 26 2017 8:32 PM
Hi Michael,
thank you for the info.
please email to:
mag@zeug.at
Detlev
Carsten
Copenhagen, Denmark
Posts 44
Carsten replied on Sun, Mar 26 2017 9:42 PM
I have just linked a ReadyNAS 102 to my BS5 Encore. It did detect it, however as I was playing around with the settings I managed to disconnect the NAS from the BS5 Encore - whereafter it din not detect the NAS.
After a restart (NOT rescan) of the Encore - the NAS was again detected.
Try a restart :-)
Wild Ruedi
Zürich Switzerland
Posts 102
Hello Michael
I am fighting the same problem: no NAS detected by the Encore.
Could you please provide me with the B&O guide?    email:  ruedi.wild48@bluewin.ch
Thank you! Best regards
Rudolf
BeoVision11, BeoVision10, BeoSound 5, BeoSound 3500, BeoLab 9, BeoLab 4, BeoLab 6000, BeoLab 8000, BeoSound 3200, Beosound Moment,NL/ML converter, delaybox, var.BeoPlay Speakers
Omid Moshtagh
Burlington Ontario Canada
Posts 50
Hi Aussie,
I just got a beosound 5 encore, it is connected to my router wifi which is connected to my wd mycloud. but the beosound does not give me any option to view my media.
Any help would be so much appreciated. you mentioned to go to the service menu how do you do that? and how to see my music on the dlna/wd mycloid?
My email is omid@yahoo.com
Thank you so much for your help.
Omid Moshtagh
Posts 50
Resolved
Wild Ruedi
Zürich Switzerland
Posts 102
Hi Omid
How was your problem solved?
regards Ruedi
Omid Moshtagh
Posts 50
Hi Ruedi,
I had to re read the manual a few time to catch the step I was missing
> Switch on BeoSound 5 and use the pointer to highlight MODE. > Turn the wheel to select SETTINGS, and press > twice, then GO. > Use the pointer to highlight SERVICE SETTINGS. > Turn the wheel to select MUSIC SERVER and press GO. > Turn the wheel to select YES and press GO. You may have to wait for a while before your BeoSound 5 can be selected as a music storage in your BeoSound 5 Encore music system.
https://www.bang-olufsen.com/~/mediaV3/Files/User-Guides/BeoSound5/beosound5-encore_userguide_english.pdf
Let me know if you have problems.
Simbamurin
Posts 1
Hie Michael, I've just come across your reply to someone else's question and would please ask you to forward the user guide to me too if you still have it. I would be really grateful as my beosound is giving me headaches. My email is simbamurin@gmail.com.
Kind regards
SIMBA
Page 1 of 1 (12 items) | RSS
