Hello Beoworlders
After gradually shifting from the classic ML Beo world to the new NL world, I still have a Beosound 3000 without any speakers which is not used anymore.
I am thinking or re-activing it for my study as a stand-alone set-up, by added a couple of Beolab 2500. However, I noted that these speakers are fairly scarce on the second hand market.
Before taking the plunge, I would like to understand from your experience how these speakers are soundwise (eg. compared to Beolab 4000's or BL4's).
Furthermore, what are the main differences between Mk1 and Mk2 (except for the frets). Should I go for one or the other?
Finally, are there any particular problems I should be aware of? Eg. how about foam rot?
Looking forward to your experiences!
Jan
Hi
BL2500 sound 5/10
BL 4000 sound 7/10
BL4 sound 6/10
Refernece is BL5 or like
so BL 4000 are best possible option!!!!
Thanks for feedback!
So would score BL4 better than Beolab 2500. I was not aware of that
bl4 have better mids an high tones..
BL 2500 better bass.
price difeesence is 100%
You can buy BL 2500 for 200€+
BL4 are 400€ +
I agree with the stack ranking above. In my opinion, the BL4000s are quite remarkable for what they are. I also like the fact that you have so many color options and they also can be easily wall mounted.
I actually have 2 pairs at the moment - One is the MK1 which employs a class A/B amplifier and the Mk2 which uses a class D IcePower unit.
Unlike some here, I actually prefer the sound of the MK2 version but the MK1 has the advantage of having both Powerlink and RCA line in whereas the MK2 is Powerlink only so will require and adapter to connect do a non Powerlink system. Unlike the MK1's, the MK2's don't have a power switch and so only come on when a signal is detected via the Powerlink socket.
As far as price (using USD and eBay as an example) a good pair of BL4000s can be had for between $2-300 if you shop around.
One thing I will point out is that if you happen to purchase a good working pair of MK1 BL4000s, the VERY FIRST thing you'll want to do is take them apart and remove ALL of the internal foam - That stuff degrades into a horrible goo that will ultimately destroy the internal electronics and sourcing new amplifier and power-supply boards for these isn't cost effective. Rest assured, though, that if you do get MK1s in working condition AND clean them up on the inside, they should work for many more years.
Take care
Greg
Beocenter 9500, Beomaster 6500, Beolab Penta MKII, Beolab 5000, Beolab 3000, Beolab 4000 MKI, Beolab 4000 MKII, Beogram 3300, Beogram 3000, 2X Beolink 7000 RDS, 2X MCP 6500
marexy:bl4 have better mids an high tones.. BL 2500 better bass. price difeesence is 100% You can buy BL 2500 for 200€+ BL4 are 400€ +
Wait some time.
You will find it on Ebay for 200€ in time :)
Yes ..agree ..BL 4000
MK1 have some issue with foam rooth.
If you remove it and clean inside and add new foam or like than it's better option as MK2.
Class D amplifier is not as long lasting as MK1 amplifier. I have mine for 17 years with no problem at all!
