The battery of my BeoSound 3 needs to be replaced (circa 15 minutes at moderate level).
The touch panel, the antenna and the loudspeaker are fine.
A dealer charge me 150€, it's too expensive!
Do you know if :
- I can find an equivalent battery model?
- Can i change the battery myself? I didn't find any instructions on BeoWorld or on the net.
Here's a topic of repairing the top plate. Might help you to get the battery out:http://archivedforum2.beoworld.org/forums/p/1432/85173.aspx#85173
Battery replacement is very simple - remove 4 screws on the base plates, disconnect two wired junctions and the earth from the PCB. Remove the screw holding the battery in place and it just slides out. You will see the tab on the end of the battery to pull it by. It is padded - which my have broken down and stick to the battery slot - but it will easily remove
