Has anyone figured out a good substitute for the original rubber feet? I'm working on a three-footed table that would be MUCH more level with a fourth.
If you can't find an original, it's usually easier to remove the remaining three and use a new set of whatever feet/pads that are close to correct height. Even pads that attach with double sided tape are probably good for another 10 years. By all means hide the original feet safely somewhere inside the deck for posterity!
--mika
Thanks. Yes, replacing all of them with something else is my plan B.
