Mute relay suggestions
This post has 11 Replies | 2 Followers
Johan
Uppsala, Sweden
Posts 239
Silver Member
Johan Posted: Tue, Aug 28 2012 10:28 AM
Hi everyone!
I have a Beomaster 5500 with a shot mute relay. I also have a couple of similar units that probably will need the relay replaced sometime soon. Now, my question is whether someone has had good or bad experiences with any particular make or kind of that type of relay? If there's a particularly good/recommended one please point me to it.
Thanks!
/  Johan
DMacri
United States
Posts 881
DMacri replied on Tue, Aug 28 2012 12:16 PM
Send a PM to Dillen. I'm sure he can set you up right.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Johan
Uppsala, Sweden
Posts 239
Silver Member
Johan replied on Wed, Aug 29 2012 9:10 AM
DMacri:
Well, I know that Martin most definitely can answer my question, but sending him a pm kind of defeats the purpose of the forum, no?
I've been searching the forum and nowhere do I find a discussion on relays, and that's why I ask.
/  Johan
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
There were one or two discussions regarding relays on the old forum, you will probably find them in the archived section.
I use the 6v version of this one
http://www.maplin.co.uk/6-and-12v-5a-miniature-relays-2525
not because it is particlarly good on quality or price but mainly because ordering is convenient.
Regards Graham
solderon29
U.K.West Midlands
Posts 764
solderon29 replied on Wed, Aug 29 2012 11:23 AM
I too can vouch for the Maplin relay.I've been fitting them for years with no problems later.
You need to cut off two pins,as it's changeover relay and won't fit to the board with the extra pins in place,but otherwise it's fine.Take care with desoldering,as the printed circuit is easily damaged around the relay site.
Nick
Johan
Uppsala, Sweden
Posts 239
Silver Member
Johan replied on Thu, Aug 30 2012 10:59 AM
Ok, thanks!
/  Johan
DMacri
United States
Posts 881
DMacri replied on Mon, Oct 15 2018 2:25 PM
I’ve found that I have some static sound when I first unmute my BeoSystem 6500. If I adjust the volume, I can break through the poor connection and get clean sound. It doesn’t take a lot of changes to do so, so at least I can still get some use of the system while waiting to replace the relays. Just something to try to buy some time before you complete your replacement.
Dom
solderon29
U.K.West Midlands
Posts 764
solderon29 replied on Fri, Oct 19 2018 11:55 AM
With the sad demise of Maplin Electronics here in the U.K.another source of suitable relay's is Farnell.
I understand that the modern equivalent of the original Omron relay is also now obsolescent,so I've been using a Finder relay,which seems to work quite happily .
CPC (Farnell) part No is SW02485.
Nick
Beomatt
Posts 6
Beomatt replied on Wed, Mar 6 2019 8:39 PM
Hi Nick, just read your post and could not find relay you suggested on Farnell, can you possibly advise me on any other replacement relay for my BM6500. I have lost right channel on Speakers output 1 (via relay) speakers 2 output works ok, mute button clicks relay and after a few times both channels sometimes work on speaker output 1.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Mar 6 2019 8:47 PM
I have the solution in the drawer.
PM or email me.
solderon29
U.K.West Midlands
Posts 764
Still available from CPC(SW02485).Farnell is their parent company,but if you search on the Farnell site,it will be under a different part No.
The Finder reference No is 4052-9006.If you search for that,you will probably be offered other suppliers too!
Nick
interloper07
Posts 6
The Finder 40529006 is also available here for those of us Stateside:
https://www.newark.com/finder/40-52-9-006-0000/relay-dpdt-250vac-8a/dp/88K3163?scope=partnumberlookahead&ost=40.52.9.006.0000&searchref=searchlookahead&exaMfpn=true&ddkey=https%3Aen-US%2FElement14_US%2Fw%2Fsearch
I just ordered two this weekend to replace a bad mute relay.
Page 1 of 1 (12 items) | RSS
