Thank you all for your help, I got this receiver going, works great with Beolink 1000, but here is another problem: When you turn it on, the balance shows O3(means the right channel is louder then the left), the treble shows -5(it should be at O meaning flat) and the bass shows +3, I can use this 1000 remote to correct the balance and bass etc, but once you turn it off and turn it on again, it is back to where it was before.
Anyone has any idea what could be the problem and solution here?
Also, is there a way to find out how old a B&O equipment is, I know Naim Audio has all the records of their products sold, and the year made.
Cheers
Do you remember to store the sound settings as defaults ?
When you have finished making your adjustments press STORE STORE on the remote and it should remember these settings for each time you switch on.
Regards Graham
Thank you Martin and Graham, I did figure it out, and now it is working great, if it does something again, then this thing would be scary, that would mean it has a mind of its own and this thing is alive. Just kidding!
It is working ok for now, will keep you posted thru this, Many Thanks for your help once again.
Khalid(Kal)
