Uhm - this was refering to the 'april' product.
Simonbeo: " .....can't say. All this not being able to say anything about the first launch in a few weeks is driving me up the wall, so to speak !! Up the wall. So to Speak (er ) No clues there then Lee!
This is how my post should have looke like (can't edit on my iPad/Safari, sorry):
Not a speaker, maybe!
Refered to as a 'concept' ----- maybe something that becomes a product, when other things come together, then.
Something to do with multiroom ;-)
9 LEE:What can I safely say for now? Well, one item is a concept - which is also a product. Totally caught me by surprise, and when you see it (and it needs to be seen and experienced) you'll have that lightbulb "yes, of course, why didn't I think of that?!" moment.
StKong: Sound transmission through the power chords eliminating the need for Ethernet or wifi?
That would be using the Powerline technology - not fancy enough for us ;-)))
Millemissen:That would be using the Powerline technology - not fancy enough for us ;-))) MM There is a tv - and there is a BV.
Barry Santini:The BL90 may not 'look' like previous Jensen/Davis designs. If you look at the BL19, various new Beoplay models, you are seeing B&Os new design language. Such fun!!
Such fun!!
And 9Lee wrote previously:
'The second product isn't being launched until August !!! So, I'm going to have to keep my mouth shut and sit on my typing fingers for months 😩 It will divide opinion as I have a feeling it's not what you'll 'expect' - but after spending a couple of days around the product, and having a demonstration, it's DEFINITELY good enough to wear the Bang & Olufsen name.... '
These guys were involved in the process of making the BL90 and the BS Moment and the 'wheely':
http://www.noto.design/
Have a look at the grafically teaser for the BL90 and compare that to the left/button figure on the Future Sounds invitation.
Millemissen:Have a look at the grafically teaser for the BL90 and compare that to the left/button figure on the Future Sounds invitation
The graphics mentioned is in my post and in the invitation for the Future Sounds, that 9 LEE posted initially in the thread (the 'shape' in the left corner at the bottom.).
As for design language, I find similarities - but maybe thats just me ;-)
Of course there is no mentioning on the noto design site - how could there!
StKong:Sound transmission through the power chords eliminating the need for Ethernet or wifi?
I also read something in the line. Could it be panel speakers like Beolab 3000 in a morden look with multi room functionality.Great if they could be used in a surround setup and multi room in on speaker. looking forward to what it will be.
Interesting!
BeoNut since '75
elephant:I hope they are improving our listening experience : : A range of cubes for the average bachelor's home,modelled on Struer's famous testing chamber, would be great. 😆
Kind of a Silence Of The Lamb thing? It puts the lotion on its skin, and if it screams no one can hear!
Jeff
BeoGreg:Now, that would be absolutely Fantastic (for me the no wifi guy).
Jeff:Kind of a Silence Of The Lamb thing? It puts the lotion on its skin, and if it screams no one can hear! Jeff Beovirus victim, it's gotten to be too much to list!
Aussie Michael:So like a WISA-NET? Then
Aussie Michael: BeoGreg: Now, that would be absolutely Fantastic (for me the no wifi guy). So like a WISA-NET? Then
WiSa is basicly wifi - so nothing for 'the no wifi guy'!
StKong: Aussie Michael: So like a WISA-NET? Then Yes! If it were my company that would be the road I'd be pursuing, and I would patent it heavily. BeoLink for the new millenium.
WHY?
We already have NL to connect devices - that you can run over wireless or wired over longer distances (and soon maybe even from a remote location).
And we have WPL (WiSA) for the speaker connection, which is working in multichannel setups.
Millemissen:WHY? We already have NL to connect devices - that you can run over wireless or wired over longer distances (and soon maybe even from a remote location). And we have WPL (WiSA) for the speaker connection, which is working in multichannel setups. MM There is a tv - and there is a BV.
That would be ethernet over power aka Powerline.
And it would require a speaker with a built-in web-client (and a web-server on the sender side).
Otherweise, how would the speaker know which sound-signal to pick from all those floating on the electric installation?
Not an easy task.
Or how would you modulate/add a specific sound signal (e.g. the left surround channel from tv-x) to a 'normal' power supply and tell the speaker to pick exactly that one.
Millemissen:That would be ethernet over power aka Powerline. And it would require a speaker with a built-in web-client (and a web-server on the sender side). Otherweise, how would the speaker know which sound-signal to pick from all those floating on the electric installation? Not an easy task. Or how would you modulate/add a specific sound signal (e.g. the left surround channel from tv-x) to a 'normal' power supply and tell the speaker to pick exactly that one. MM There is a tv - and there is a BV.
So - my last post to this...in order not to hijack the thread ;-)
Sure, it would be possible, but at which costs?
And when there already are solutions, why spend limited man, brain, money power at B&O to do this?
Millemissen:So - my last post to this...in order not to hijack the thread ;-)Sure, it would be possible, but at which costs?And when there already are solutions, why spend limited man, brain, money power at B&O to do this?MMThere is a tv - and there is a BV.
StKong: I don't know about costs. Ease-of-use and integration are Bang & Olufsen hallmarks — and essentially what sets the brand apart from the competition.
Sorry, but that's no hallmark of Bang & Olufsen, except you call the procedure "n.music + go + 4" on a Beo 4 "easy" or "intuitive" to access A.Aux on the Beomaster 5 when it is in Slave mode. ;-)Let's just wait and see what Lee and B&O will show us.
elephant: Jeff: Kind of a Silence Of The Lamb thing? It puts the lotion on its skin, and if it screams no one can hear! Jeff Beovirus victim, it's gotten to be too much to list! Not at all ! My hair is standing on end like Beaker's from the Muppets !! I was taking Lee's hint to the extreme When we see it we will say "now why did I not think it" Besides which the Struer chamber is quintessential B&O search for perfection.
Not at all !
I was thinking of an anechoic chamber and it's potential uses outside of audio! Gee, you try and think outside the box as it were and look where it gets you.
Beaker, always loved Beaker. The world's most abused lab assistant.
Dear Millemissen,
I guess we talked to each other at the Struer Museum last week? Sitting next to Lee for the dinner the night before and our chat made me curious enough to subscribe to beoworld and following your guesses.
Best, André
A good article in Pocket-lint at the end mentions that they were at the press days and looking forward to the reveal.
http://www.pocket-lint.com/news/140624-bang-and-olufsen-at-92-a-closer-look-at-how-the-luxury-brand-found-its-success
Jeff:I was thinking of an anechoic chamber and it's potential uses outside of audio!
Remember that our measurement room is only anechoic inside the computer - not in real life. We gate the measurements before the reflections come in, so any potential uses would have to be virtual...
Cheers
-geoff
Geoff Martin:Remember that our measurement room is only anechoic inside the computer - not in real life. We gate the measurements before the reflections come in, so any potential uses would have to be virtual... Cheers -geoff
Noto: Dear Millemissen, I guess we talked to each other at the Struer Museum last week? Sitting next to Lee for the dinner the night before and our chat made me curious enough to subscribe to beoworld and following your guesses. Best, André
Welcome to Beoworld, André.
Tach André,
sure we did - was a nice, but a bit too short chat (you had other things to do there, I know).
Nice to meet someone (of many), who is involved in designing the current B&O products and to experience your enthusiasm for the brand.
I see, that TWG already welcomed you on Beoworld ;-) -
I hope you will find the time to read and maybe also give some comments here, where it would fit in.
Thanks for the warm welcome. I will try my best to comment...but for sure I will listen attentively.
Best,André
Super nice. A woman thing.
Peter Pan: A woman thing.
A woman thing.
Might be - depending on your take on design.
I guess you are more for the strong, steady take of the Penta-obelisk ;-)
Anyway - that is a study from one of the 'twelve up and coming industrial design students from Aalto University,
who expressed their vision of sound and created a selection of loudspeakers that explore form, function and materiality' In 2016.
Peter Pan: << BeoLab S >>Super nice. A woman thing.
Cheers! As the designer of those speakers, I was going for a warmer look than B&O's current offerings – but I see them more as a "nice thing" that can appeal to anyone, rather than a "woman thing" (also being a man myself)
By the way: this, as well as seven other concepts, can be seen at Milan Design Week 4th–9th April. If any of you happen to be there, come by Circolo Filologico Milanese and say hi!
Back on topic now!
— Tuomas | Bang & Olufsen | Bang & Olufsen Create
Hallo tph
Then you also have a bid on my BeoLab design
Greeting Peter Pan
Something B&O should look at : https://www.urbanears.com/ue_us_en/baggen (design is quite nice and function wise, yes!)
L1NO: Something B&O should look at : https://www.urbanears.com/ue_us_en/baggen (design is quite nice and function wise, yes!)
Those look fantastic. I'd take that over many of the Beoplay products. Looks better and way cheaper. Hopefully sound just as good as they look.
BeoLab 18's. Beolab 3's. A8. A9. A2. H7.
