Hi all! New here but a long time (1970s) B&O owner and user.I purchased the Beoplay H9 to my wife in February and have since got them replaces three times. Dead-on-arrival all three times. Initial purchase: charging doesn't work. Second: loose connection to one of the microphones (cracking sound when moving head). Third: loose connection to the other mic. Now one the fourth pair, which seems to work as they should.Anybody else experienced this with the H9?
No problems here. Purchaased mine by ordering a pair from a B&O promo mail on release date. Very happy with them and use them daily.
I had though similar quality experience with my former H8 / had gotten though replaced them three times. I was persistent until I got the B&O quality I had paid for.
Good luck!
Hello
I have a problem too...the charge only lasts about a day or so, even when the headphones are not used?
In addition if I try to charge the headphones (via the USB cable) whilst they are plugged into my laptop, I hear a loud hissing sound and I'm not sure if the noise cancelling function is working as I can't hear a difference between it being turned on and off :(
Has anyone else noticed this?
TCMuffin:Hello I have a problem too...the charge only lasts about a day or so, even when the headphones are not used?
