Replacing LCD on a Beo4 : easy or not?
This post has 5 Replies | 0 Followers
mbee
Paris, France
Posts 1,842
mbee Posted: Thu, Aug 30 2012 1:37 PM
Hello...
Unfortunately my GF used my Beo4 as a trampoline... So now the LCD screen is broken.
Good news : she didn't do that with the Beo6 Smile
Now I've got a little question : I've got the Beo4, I've found where to buy a new screen... So : is it easy to replace it myself (I'm used to repare some little electronic devices), or is it tricky, and recommended to ask a professional to do that?
Chris Townsend
Qatar
Posts 3,531
mbee:
Hello...
Unfortunately my GF used my Beo4 as a trampoline... So now the LCD screen is broken. Good news : she didn't do that with the Beo6
diisign.com
The Beo 6 would need more than a screen trust me. No offence to your girlfriend :-/
Vienna
make an educated guess
Posts 1,090
Vienna replied on Thu, Aug 30 2012 2:07 PM
... assuming you have the reqired tools to dismantle a Beo 4 and follow the instructions supplied with the sparepart
replacing the display won't be a very complicated task.
mbee
Paris, France
Posts 1,842
mbee replied on Thu, Aug 30 2012 2:22 PM
@Chris : I know that approximately the full remote is hidden behind the Beo6 screen...
@Vienna : I've got the service manual, and the only tool seems to be a standard screwdriver (no torx implied), so I think that I will do the repair myself... Thanks!
tournedos
Finland
Posts 7,357
tournedos replied on Thu, Aug 30 2012 2:36 PM
The trickiest part is finding the last screw under the bar code sticker, unless you know about it Big Smile
Keep everything clean and think before doing, and you'll be fine.
--mika
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Thu, Aug 30 2012 4:33 PM
I had a failed Beo4 screen about 18 months ago (almost zero pixels). Had it replaced by a dealer while I waited. I didn't pay too much attention, but it was all done in about 5 minutes. Once the Beo4 was open it just looked like a simple pull-out and plug-in job. The only charge was for the part.
Graham
Page 1 of 1 (6 items) | RSS
