Beosound 5 encore
This post has 2 Replies | 2 Followers
Peterskov
Posts 4
Peterskov Posted: Sat, Sep 1 2012 9:42 AM
I can't connect to my Iomega Nas hdd, it's a Lan connection. My xbox, pc etc., have not this problem.
The Beosound does not display any options in "search music store" and it is not highlighted.
It's not a problem to "ping" the Beosound from my pc
Can I reset the Beosound? If yes  - how?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Sep 1 2012 5:28 PM
Your Iomega normally has a media server installed. The question is; is the server running?
If the server is ON then, because Iomega normally works with Twonky, the storage should be detected by your BS5e. If it is OFF it can't be detected by the BS5e!
Peterskov
Posts 4
Thank you for your reply Carolpa. After a reset of the Beo5 it works.
Peter/Denmark
Page 1 of 1 (3 items) | RSS
