I received from estate a beomaster 5500. It physically looks great, but it simply doesn't power on. What are the possible problems and costs of fixing.
Could be anything from a cracked solder joint that costs 2 minutes to find and fix to completelyburned down innards from a lightning strike which would be nowhere near worth a fix.It will have to be diagnosed by a tech guy to answer your question exactly.
ericthered325: I received from estate a beomaster 5500. It physically looks great, but it simply doesn't power on. What are the possible problems and costs of fixing.
I would suggest putting your question into a sub forum which would be more suitable...here its Beomaster 5 (five); this has nothing to do with you master! Regards elmar
