Some time ago I bought a convolute of Beolit radios for spare parts. I used it to finish few of restorations of my nice Beolits. Now I am finished and I do not need those parts anymore. I made few pictures today and you can look to them, if you can find anything for you. If you need detailed pictures, please write me back.
The price? You can decide by your self (anything you will to pay for it)
Vintage Bang & Olufsen
Hi Ben,
yes I got few grey pegs too but I used them all for my Beolits. There is only one more grey peg and 20-25 of the black ones (they have same dimensions but different color)...
Ohh, do you have of the ferrite rod plastic clips that support the rod? I have a radio with a floppy ferrite rod. I think they may be identical but I'm missing the one on the left.
Thank you!
If you think nobody cares, try missing a couple of payments.
thanks for your interest. I am not sure which part you are looking for exactly. For which Beolit model is it? Do you have maybe a picture or even better the part number from service manual?
Regards / Theomaster
Thank you Theomaster.
It is the 70's Beolit 700. Item No. 64 Part number 3152052
I also have a few others like the 707 with the usual missing volume & tone sliders so if by chance you have any of those too.
Many thanks,
Steve
Do you have an extendible antenna, the one that extends out the top of the case. If so, I'd love to give it a good home.
Mark
Stonk: Thank you Theomaster. It is the 70's Beolit 700. Item No. 64 Part number 3152052 I also have a few others like the 707 with the usual missing volume & tone sliders so if by chance you have any of those too. Many thanks, Steve
Hi Steve,
I finaly found some time to look to the parts. Yes, I have few of those ferrite rod plastic clip. See pictures, are you looking for those?
I found also few of those volume & tone sliders but they are all either broken or already repaired :-(
Anyhow I can send them to you and you can try to use them...
Best regards / Theomaster
Mark: Do you have an extendible antenna, the one that extends out the top of the case. If so, I'd love to give it a good home. Mark
Hi Mark,
no, unfortunately I do not have antennas anymore
BR / Theomaster
Brilliant, thank you. I'll send a PM.
Hi
If need some slide buttons for Beolit 600/700 in Silver and Black, and a handle in silver and one in black if you still have some for sale
Please write me on
pfinkh@gmail.com.
Best regards
Poul Fink Hansen
Denmark
Thank you for looking for the extendible antennas. Much appreciated.
