Hello I'm new this forum
Sorry for my poor english, I have B&O 3000 amplifier and I try to fix it.
Both channel are broken.
I have changed left/right side capacitor
100µF 35v 3+3, pcs (475,553,473,558,447,553)
47µF 50v 1+1 pcs (458,546)
22 µF 63v 1+1 pcs (472,561)
10 µF 63v 2+2 pcs (420,500,412,505)
And also left channel
TR.62 org.BC311 à 2SA1020Y
TR.64 org. 2N3055 à2N3055
Now the left channel works well
And Right channel
TR.49 org. 2N3055 à2N3055
TR 43 org. BC183L à BC183A
TR.44 org. BC310 àBC639-16
TR.46 org. BC262B à BC415A
TR.47 org. BC311 à BC161-16
Right channel input 60V (red wire) quiescent current should be ab.100mA ?
when I tested (ampere meter range 0.6A) and as soon as the power cord a bit touched the pin, meter jumped to the bottom
When I put the right channel external power supply (0-25V), so it works (25v) and the current is only n.20mA.
Should there be any tips how to fix.
Replaced transistors are too different from the original ?
suggestions for better transistor ?
