I have a beovision 7/55 with BeoLab connected to the tv, connected via Masterlink, a beosound 9000. I want to connect to both a beosound 5 and I bought a Masterlink distributor. A-OPT 0 for beosound5 and 9000. 2 tv.
I connected everything but does not work. If I active beosound 5, the TV does not turn on. Same thing activating the BS9000.
Can you give me some help?
I have BS 9000 (Audio Master) and BS5 (Slave) work perfect. BV7 Videomaster
BeoVision 7-40 HD-Modul, BeoViision 11-40, BeoVision 8 32" white + Floor Stand, 2x Apple TV 4 mit Kodi, DVD2, HDR2, BeoSound 9000 MKIII White Edition, 2x BeoSound Moment + Floor Stand, 2x BeoSound Stage, BeoSound Core, BeoSound 35 brass, BeoSound 1 MKII + Floor Stand, 2x BeoSound 3, BeoSound 6, BeoSound 3200, BeoSound Essence , BeoPlay A9 Nordic Sky twilight, BeoPlay A8 MKII white + Floor Stand, BeoPlay A2 grey, 2x BeoPlay A3 white/bright blue, BeoPlay A1, 2x BeoPlay S3 white, Beolit 12 (White Edition), Beogram TX2, BeoLab 5, BeoLab 3, BeoLab 7-4, BeoLab 8000 MKII, Beolab 11, 2x BeoLab 3500, 4x LC2, 4x Beo4 - MK1-3, BeoRemonte One BT, 2x BeoRemonte Halo, Audio Terminal, Beolink 1000, BeoLink 7000, 2x EarSet A8, 3x A9 Keyring, EarSet 2, Form2, BeoPlay H6, 3x BeoTime, Beowatch, 2x Lightmanager Pro+ B&o Version, 4x BeoCom5, Beoline2, 3x Speakerphone, BeoTalk 1200, 5x Cabinets, MLGW, BLGW,
SlyParma: I have a beovision 7/55 with BeoLab connected to the tv, connected via Masterlink, a beosound 9000. I want to connect to both a beosound 5 and I bought a Masterlink distributor. A-OPT 0 for beosound5 and 9000. 2 tv. I connected everything but does not work. If I active beosound 5, the TV does not turn on. Same thing activating the BS9000. Can you give me some help?
Set your BS9000 to A.OPT 0 (audiomaster), your BS5 to NO AUDIOMASTER and your BV7 to V.OPT2 (videomaster).
BS9000 sources are RADIO, CD
BS5 sources are N.MUSIC GO 1 - 4.
Stefan
OK thanks . But when I turn on Beosound 5, does my TV turn on to start speakers?
