beolink 1000
This post has 17 Replies | 6 Followers
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 Posted: Sun, Feb 5 2012 3:36 PM
Was there ever a wall bracket made for above ?
bayerische
Ekenäs, Finland
Posts 4,770
I don't think there was.
Too long to list....
Seanie_230
UK
Posts 2,278
Hi there
Ref was my friend has his beolink 1000 on the wall in his kitchen
100% YES lol
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Thats Yes not Ref no edit button.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Certainly yes. No longer made but often available on ebay.uk
I think there are a couple on ebay now!
Regards Graham
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
Would the Beo4 bracket not work, maybe a little loose?
  • One B&o bottle opener
  • One fancy gun
bayerische
Ekenäs, Finland
Posts 4,770
Cool! I didn't know there was. If this would have been Trivial Pursuit, I wouldn't have gotten my piece of cake! []
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
joeyboygolf:
Well, there you are! Embarrassed
  • One fancy gun
Seanie_230
UK
Posts 2,278
No i dont think so they Beo4 is a different shape and thicker so they 1000 would fall straight through.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
joeyboygolf
Posts 4,188
The Beo4 bracket is not wide enough
Regards Graham
Seanie_230
UK
Posts 2,278
yeah that too
joeyboygolf:
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
valve1
Posts 1,502
valve1 replied on Sun, Feb 5 2012 4:04 PM
joeyboygolf:
You are correct, just tried it !
I will check ebay thanks.
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Feb 5 2012 8:05 PM
Graham is quite correct - I did have a few which my old dealer gave me - goodness only knows where they went though. I confess to never using them - far more convenient to have them close by - even if Brutus sits on them and turns the TV on!
Peter
Medogsfat
Leeds West Yorkshire
Posts 3,896
Yep - I once owned one for about 2 days after which I promptly gave it away. Very cheap plasticky thing that was more trouble to use than worth the effort.
Chris.
Stoobietoo
Exeter, Devon, UK
Posts 692
Medogsfat:
The one I have is metal & plastic and completely "over engineered" in the usual B&O way. It is in two parts (fitted together before you get it) but that sit losely together so that the Beolink 1000 slips in an out more easily. Mine was on the wall next to my Beosystem 4500 for many years and I always found it easy to use! Either taking the remote in & out or using it in place.
I also have one for my Beolink 5000 and that definitely is a cheap bit of plastic with a piece of stick on aluminium to match the Beolink 5000. It does it's job though! and looks good with the Beolink 5000 in it.
Stoobie
Daniel
Svinarp, Sweden
Posts 1,632
Daniel replied on Sat, Mar 3 2012 4:06 PM
valve1:
I have one on the wall next to my bed. It's perfect.
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Sat, Mar 3 2012 4:49 PM
Stoobietoo:
It's definetely a cheap bit of plastic. Beo 4 wall bracket fits the Beolink 5000 perfectly!
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
Leslie replied on Sat, Mar 3 2012 4:51 PM
Let's see for how much this (not mine) cheap bit of plastic will be sold for!
Brengen & Ophalen
Page 1 of 1 (18 items) | RSS
DigiCert Secured Site Seal
