Comparison BV 4-65, 12-65 and Avant 75 ( Black Level)
This post has 16 Replies | 1 Follower
Newbie
Posts 248
Newbie Posted: Mon, Mar 27 2017 9:07 AM
Can anybody tell me if there is a big difference between the BV4-65 (MK3) and the 12-65 with the Beosystem 4 in presentation the black level.
The 4-65 can not show a real black, it is more a grey :-(
The 12-65 has the newer plasma panel, is the black better?
A other question is about the Avant 75 (MK1).
How is the colour black on this screen?
I have seen the new LOEWE Bild7 OLED.
It has a superb black :-)
Is the black from the Avant nearby an Oled?
I hope someone can help me.
Kind regards, newbie
Beovision 12-65 NG, Beosystem 4, Beolab 7.2, Beolab 6000, Beolab 5, Beolab 4000, Playmaker, Beogram 5005, Beo4, Beo5, Beovision 7-32 MK3 (2x), Beovision 4.42, Beosystem 2 HD, Beolab 7.1, Beolab 7.4, Beovision 10-32, Beovision 6-26, Beosound Moment, Beosound 2300, Beosound Ouverture, Beogram TX2, Beogram 2404, Beomaster 3002, Beovox CX 75, Beovox CX 100, ibundo, Keyring.......
Sandyb
Posts 2,186
Sandyb replied on Mon, Mar 27 2017 10:37 AM
I have a 12-65 with BS4.....i dont know the actual stats of the panel, but its a magnificent picture.....yes i know you will have heard that before, but its worth repeating i think.....i also have a MKII screen in my new BV14-55, so have a daily side by side comparison......but even a MK1 Avant, which is arguably better than the MKII panel, is still an LCD, so its blacks won't be as good as the 12-65..........dark scenes on an LCD (and i experience this with my BV14) are handled much better by the 12-65, which i guess is my best guide.......i dont know much about the BV4-65 i'm afraid.......but i'd strongly recommend the 12-65 - with HD material, whether broadcast or BluRay, its fabulous, and looks very much up to modern picture standards......guess it depends how important 4K/HDR is for you.....
davidr
Montréal
Posts 172
davidr replied on Mon, Mar 27 2017 3:04 PM
With much respect to b&o, neither set will display true black like OLED due to LCD & PDP panels. Even as a former plasma owner there's simply no comparison to OLED.
Supposedly b&o are working on a OLED based display, personally I'd wait for that or simply buy a Loewe set today.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Mon, Mar 27 2017 3:40 PM
The BV12 65 allegedly uses the same "glass" (aka panel) as my Panasonic VT series 65 inch, and when looking at the BV 12 in the store I can believe it, performance seemed the same, in other words excellent, great blacks. I would point out that there is also another performance parameter that is as important as absolute black level, and that's shadow detail, how good the panel is at showing intermediate shades of dark gray, which is primarily a function of gray scale linearity, which can often be improved with calibration. Both minimum black level and gray scale linearity are more important than number of pixels to a good image.
I've seen OLED in the stores, but they were adjusted in the typical atrocious "display" mode, so I have no idea about their real performance other than I read they should be excellent for black levels.
Jeff
TWG
Posts 1,672
TWG replied on Mon, Mar 27 2017 3:45 PM
Best black level: OLED. No discussion needed. But the LCD screens can get brighter which is better especially on sunny / bright days.
That's due to the nature of OLED: Only the pixel that is needed will light up. If not needed it stays off and it has no backlight which can "shine" through the panel somewhere.
If my LG OLED wouldn't have a screen saver or backlit logo I couldn't tell if it's on or off ;-)
Sandyb
Posts 2,186
Sandyb replied on Mon, Mar 27 2017 3:49 PM
Let's also bear in mind picture processing, which has a sizeable influence on final image quality. I wasn't bowled over by the processing in the E6 , compared to the Sony and Panasonic sets I did a side by side with...from what I have read, the Bild has better processing than the E6
Newbie
Posts 248
Newbie replied on Mon, Mar 27 2017 5:38 PM
Thank you for all answers :-)
Another question:
Is it worth to switch from my BV 4-65 MK3 to 12-65 with Beosystem 4?
Sandyb
Posts 2,186
Sandyb replied on Mon, Mar 27 2017 5:43 PM
is 4K important to you?
Newbie
Posts 248
Newbie replied on Mon, Mar 27 2017 5:49 PM
No it is not.
Sandyb
Posts 2,186
Sandyb replied on Mon, Mar 27 2017 5:59 PM
i would, cost considerations aside....of course you get more than a panel with the 12-65, i.e. the BS4 box which is useful in many circumstances.....anyway, not cheap for a legacy product, albeit a fabulous one........there will be some forum members who would suggest spending 5-6k can be better deployed, though thats largely for OLED and 4l/HDR reasons.....a Bild 7 is also not cheap, and won't be easy to hook up with other B&O equipment.......in the end, 4K/HDR won't be a principal use case for a few years, so i dont feel the need to update my 12-65 until then.......
mjmedlo
Posts 922
mjmedlo replied on Mon, Mar 27 2017 8:01 PM
IMO the real advantage here is the beosystem4
I have enjoyed both the bv4 and bv12. The 12 is better.. but the real advantage is the sys4. It's far ahead of the sys3 for me.
The online PUC database and true image are worth the cost!
Newbie
Posts 248
Newbie replied on Mon, Mar 27 2017 8:37 PM
I think my BV 4-65 is soon for sale.....  ;-)
Newbie
Posts 248
Newbie replied on Mon, Mar 27 2017 9:42 PM
Before I bought my 4-65 I had a Pioneer Kuro FullHd.
The operation and handling was lousy bit the picture was excellent :-)
If the 12-65 has a picture that is the same like the Kuro I am ready to buy
Sandyb
Posts 2,186
Sandyb replied on Mon, Mar 27 2017 9:45 PM
i had a late edition Kuro as well (for 6 years), but the 12-65 is a good deal better......
Newbie
Posts 248
Newbie replied on Sat, Apr 1 2017 9:44 AM
I asked a B&O guy and he told me that the 4-65 should  have the better picture than a 12-65....
Sandyb
Posts 2,186
Sandyb replied on Sat, Apr 1 2017 10:07 AM
Difficult to comment, but I can't imagine there is much in it....
Sandyb
Posts 2,186
Sandyb replied on Sat, Apr 1 2017 10:09 AM
And as mentioned earlier, I also had a 50 inch Kuro, and the 12-65 is better, as well as being slimmer and having the BS4
Page 1 of 1 (17 items) | RSS
