I am trying to use the MoodWheel as much as possible right now, but I really think it is working against me :)
If I select a mood from the inner wheel, it select a few songs which is from my own collection, and then jumps to the same mood, but in the middle ring ?
Is it supposed to jump "out" if it cannot find anymore songs in the currently selected ring ?
/Jacob
Are you on the "MoodWheel study" programme?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hiort: Are you on the "MoodWheel study" programme?
Yes 😁🎼
i just can't to figure out if the behaviour I experience is correct, or if it is bugs?
or to put it in another way, I don't expect the behaviour I see :)
Weebyx: Yes 😁🎼 i just can't to figure out if the behaviour I experience is correct, or if it is bugs? or to put it in another way, I don't expect the behaviour I see :) /Jacob
As far as I know, It must not jump to the middle circle .... bust stop if there no more music to play.
mbolo01: As far as I know, It must not jump to the middle circle .... bust stop if there no more music to play.
Ok, I did some more extensive testing, and it seems that what is happening, is a mix of the X app's PlayQueue and the Moments, MoodWheel picks.
If I go into the X App and clears the PlayQueue, and verifies that no Queue is currently active on the Moment, MoodWheel works (99% of the time) as it should. In this scenario, the MW stays on the circle selected, and stops when no more songs are available.
If I however, select a song on the X App, it actually add's the song to the PlayQueue that the MoodWheel found, but it adds it after the song currently moodplaying. When the Moment gets to that song, it jumps to the middle ring (same color), but plays the song selected in the X App (which is most likely not the same mood). That causes the jump to the outer ring, however, if I then go back to the "now playing" on the Moment, selects another track(from the originally mood, and then go back to the song added from X App, it moves the white dot to the mood that matches the X App song.
I hope this makes sense :)
So I guess that the X App and MoodWheel does not play well together, at least they don't play together in a way that makes sense when using MoodWheel.
