Hello
My Beosound Encore is showing a dark red screen with the laserpointer in a Saturn like shape. Otherwise it works normal.
I have tried a reset, restart - no change. What else can I do? Thank you for your advice!
Rudolf
BeoVision11, BeoVision10, BeoSound 5, BeoSound 3500, BeoLab 9, BeoLab 4, BeoLab 6000, BeoLab 8000, BeoSound 3200, Beosound Moment,NL/ML converter, delaybox, var.BeoPlay Speakers
update: fixed a loose connection between display and board with a new cable from B&O. All ok !
Thank you for the helpful information! Glad that it works again.
