How to setup Beo9000 MK3 6 CD player with Beolab 5000 active speakers
ownerbuilder
Posts 3
ownerbuilder Posted: Thu, Mar 30 2017 10:24 AM
Hi, I hope you will be able to confirm that these have compatible display thru MK2 powerlink cables on Beolab 5000 active Amps LCD displays as I have not been able to get the displays working showing the 9000 CD or display settings onto beolab 5000 Speakers. Note speakers turn on/off and work / play ok.
Weebyx
Denmark
Posts 1,213
Weebyx replied on Thu, Mar 30 2017 10:38 AM
ownerbuilder:
Are the speakers set to AUDIO ? There is a switch with VIDEO/AUDIO/OFF somewhere :)
/Jacob
ownerbuilder
Posts 3
Hi Beolab 5000 doesn't have Video / Audio switch. I have been trying to connect MK2 cables between 9000 and powerlink on beolab 5000. The switch on the beolab 5000 for powerlink only has blank (1st) position, R (Right at 2nd position) and L (left speaker at 3rd position)
The other switch is for speaker link (requires the 4pin speaker cable that can be connected to passive amp via masterlink. I haven't tried a powerlink speaker cable as I need the 4 pin connector end to do this. If speakerlink is the only way to get the beolab 5000 displays working then I will organise to get hold of these once confirmed that is what is required.
My beolab speakers are model 6705.
Weebyx
Denmark
Posts 1,213
Weebyx replied on Thu, Mar 30 2017 11:25 AM
ownerbuilder:
Hmm, I am pretty sure there is an AUDIO/VIDEO switch on the side of the amplifier, it is well hidden :)
https://www.manualslib.com/manual/213526/Bang-And-Olufsen-Beolab-3000.html?page=14#manual
/Jacob
ownerbuilder
Posts 3
Ok found them and bingo displays work on both :)
Thank you awesome my beolabs now work as they should
Weebyx
Denmark
Posts 1,213
Weebyx replied on Thu, Mar 30 2017 11:53 AM
ownerbuilder:
Great..
/Jacob
Page 1 of 1 (6 items) | RSS
