Today my A6 got a new SW, but it is not mentioned here.
http://www.bang-olufsen.com/en/product-support/BO-PLAY-Speakers/beoplay-a6
Does anyone know what this SW adresses / adds ?
/Jacob
Eclipse 65V1-32Beosound M5Essence MK2BLI
Weebyx: Today my A6 got a new SW, but it is not mentioned here. http://www.bang-olufsen.com/en/product-support/BO-PLAY-Speakers/beoplay-a6 Does anyone know what this SW adresses / adds ? /Jacob
Same for the A9 MKII - but no idea what it does
Find me on YouTube : Bang & Olufsen Teknisk Forum : https://www.youtube.com/c/BangOlufsenTekniskForum
Same for the BEOPLAY M5 - but no idea what it does !
In the settings for my A6, I now have something called CONTROL4 ?
https://www.control4.com
Anyone head about this ?
Seanie_230:Oh have you checked if M5 has equaliser now ?
Apparently not, only the volume level through BeoSetup and the usual sound profile through Beoplay :-(
Weebyx:Anyone head about this ?
Looks like another automation system ....
BeoHut:BS1 had now settings for the sound .
BS2 as well! And what a change! I put it in corner mode (it's sitting in a corner) and it's not boomy anymore. I even didn't need to adjust bass an trebles in the menu and could deactivate iTunes equalizer that I used to reduce bass frequencies.
I started a chain, but I see now there is already a thread.
Since I updated, all my products are having issues. There's a delay and airplay and Bluetooth from any video. And half of my devices are showing as unreachable. I can restart them and it fixes it for the day.
is anyone else seeing these issues?
i heard in the middle of the night them all restart - it was like a chorus
thats how i usually know that there has been an update as you can hear it
Aussie Michael: i heard in the middle of the night them all restart - it was like a chorus thats how i usually know that there has been an update as you can hear it
And this is why mine are updated manually :)
mbolo01: Weebyx:Anyone head about this ? Looks like another automation system ....
Some info on Control4
http://stores.bang-olufsen.com/great-britain/bang-olufsen-of-cambridge/subpages/home-automation-control4/
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Weebyx:And this is why mine are updated manually :) /Jacob
Aussie Michael:It doesn't worry me I wake up and go Yes!
There seems to be less of a gap between tracks when streaming DLNA to my BeoSound 2.
Seems like this hasn't been rolled out in Denmark yet, we're apparently the last to get updates as neither my A9 nor BeoVision Horizon can find any updates.
Why must you taunt me, B&O??? Why not make it available everywhere at once?
ThatGuyFromDenmark: Seems like this hasn't been rolled out in Denmark yet, we're apparently the last to get updates as neither my A9 nor BeoVision Horizon can find any updates. Why must you taunt me, B&O??? Why not make it available everywhere at once?
Im from Denmark :)
When are they going to fix the Bluetooth issue - i've had the essence Mk2 since it was launched and it's still not usable as it should be! Does anyone have a solution that doesn't involve the IR?
Weebyx: ThatGuyFromDenmark: Seems like this hasn't been rolled out in Denmark yet, we're apparently the last to get updates as neither my A9 nor BeoVision Horizon can find any updates. Why must you taunt me, B&O??? Why not make it available everywhere at once? Im from Denmark :) /Jacob
Me 2, and I've got the update
//Vejrup
It's got to be a personal vendetta against me then :(
ThatGuyFromDenmark: It's got to be a personal vendetta against me then :(
Well, since this sw update fixes issues with... sw update.... it might be that your products suffer this issue, could be something with the network/router combination ?
Maybe a reset(wireless/wired change) of the A9 could get it to find the update ?
I tried that, no result. And it's able to play Spotify just fine, so I assume the network is working. The last update downloaded fine (1.11) and no change since that. I'll reach out to Beocare on Monday.
Found the problem - the date was off. Once I corrected the date on the A9, it found the software immediately. Didn't fix the problem on the Horizon though
