Distribute airplay via NL
steve1977
Posts 911
steve1977 Posted: Sun, Apr 2 2017 9:22 AM
Understand that airplay can now be distributed in multi-room setup.
One Q - does this also work with the ML/NL? I am playing to an A9 via airplay, but don't know how to distribute the airplay to an ML/NL converter connected to a BV. In the setup app, there is no airplay source.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Apr 2 2017 9:51 AM
what happens if you give a CD2 command to your BV?
the BLC is setup as A.Master?
steve1977
Posts 911
steve1977 replied on Sun, Apr 2 2017 10:32 AM
Works when I selected DVD2 (there is no CD2 on BROne). Would love to use it over the Beomusic app though. Not possible?
Page 1 of 1 (3 items) | RSS
DigiCert Secured Site Seal
