Help with IR and sound disribution from Beosystem 3 ( partially answered)
Stoobietoo
Exeter, Devon, UK
Posts 692
Stoobietoo Posted: Sun, Apr 9 2017 9:53 AM
I have just bought a Beosystem 3 to replace my Beovision 5 and I'm having fun trying to set it up. I'm using it with a temporary TV. It has the DVB-T/S module and has the two DVI outputs as opposed to HDMI on the newer versions. I have an older Humax STB connected via scart, that I use for recording shows and an Amazon Firestick connected via HDMI. It has two Beolab Pentas connected and linked to a Beosound 9000 via Masterlink along with a Beolab 3500 in the same room and a couple of link rooms. The Beosystem is option 2 and the Beosound option 0.
I have a couple of questions.
1. Which IR emitters are compatible with the PUC outputs? Do they have to be B&O?
2. The Firestick has KODI installed for my music streaming. I can view the Firestick on screen and play my music through the connected Pentas. But I cannot get it to play through the link to the BL3500 or rest of the house.
However, I can distribute the DVB-T sound and the Humax sound to the BL3500 and link rooms. I use AV,  then press DTV. (Answered below)
Any suggestions?
Stoobie
Millemissen
Flensborg, Denmark
Posts 14,680
ML can only distribute sound, which is connectet through analog-in.
With the Firestick you would have to use a HDMI Audio Extractor in order to have an analog output to feed into an analog input on the BSys3.
Stoobietoo
Exeter, Devon, UK
Posts 692
Aaah.... Thanks Millemissen, I thought it might be something simple such as that. I'll dig out my trusty old Raspberry Pi which I used to run KODI on. I can connect that to one of the analogue inputs.
Stoobie
Page 1 of 1 (3 items) | RSS
