Hello!
I recently bought an BeoVision 4 50".
The person i got it from said i can use it only as a PC screen as he doesn't have a BeoSystem.
I connected the screen to a PC but it doesn't boot up and from what i understand i need a BeoSystem for that.
Is there a way to use the screen without a BeoSystem?
Search and buy an original Panasonic remote (commercial ones).
Point that under the left bottom corner. You can then change several settings and manually switch on or off.
Another option is to remove the bessel to get acces to the buttons on left hottom of the panel.
