Beolab 2 question
andrew
Sussex UK
Posts 47
andrew Posted: Mon, Apr 17 2017 3:51 PM
Hi. I bought a beolab 2 to go with my beolab 8000's and found it didn't work. So I had a new driver unitl fitted - and it sounds really good with the 8000's. BUT - twice in the last 10 or so days it has blown the 3 amp fuse. Is this normal? Or should it be a 5 amp fuse? It wasn't even loud music - just went.
Also, while it sounds great with some music - there is one track in particular (a track from the musical "Cabaret") where the treble is SO quiet that it is almost missing (the track which goes "fiddly diddly dee, 2 ladies"!) Most odd.
Thanks in advance.
Andrew
Beo_Jean
QC, Canada
Posts 334
Beo_Jean replied on Mon, Apr 17 2017 4:36 PM
Andrew,
Never go over the rated fuse capacity otherwise you will damage the amp or spreakers or both.
If you are blowing fuses, that means you have something which isn't running right.
Try another set of speakers a see if you are still blowing fuses.  If you do, you must check the amplifier side, if not, check the crossovers capacitors.
Page 1 of 1 (2 items) | RSS
