Beogram 4000 broken tonearm
Dom Keen
United Kingdom
Posts 10
Dom Keen Posted: Mon, Apr 17 2017 7:12 PM
Hello beoworlders
So my beogram 4000 always had a fragile tonearm, just where the stylus attaches. The metal clip that inserts into the bottom of the pickup has just broken off :-(
Any tips or advice on how I can get this fixed or source a replacement part and get it fixed?
thank you all in advance :-)
warmest regards
Dom Keen
UK
sonavor
Texas, United States
Posts 3,732
sonavor replied on Mon, Apr 17 2017 7:29 PM
Hi Dom,
Your Beogram 4000 tonearm problem is not uncommon. I have had to fix that problem on both of my Beogram 4000 turntables. The first one I repaired by stealing a new cartridge mount from a spare Beogram 4004 turntable (same cartridge type mount). You can see that repair here (towards the bottom of the page). On the second Beogram 4000 I worked with Beoworld member Beolover to try a 3D printed replacement part for the cartridge mount. That way another Beogram tonearm doesn't have to be sacrificed. You can see that repair here (about a quarter way down the page). Both repairs worked great and haven't given me any problem.
Regards,
sonavor
Dom Keen
United Kingdom
Posts 10
Hi Sonavor
Firstly, apologies for the late response, I forgot my login details to the forum!! Back in now...
I am trying to get a broken 4004 at the moment on eBay so I can use the tonearm, if I do not win then I think the 3D printed option may be my only choice.
Do you or any other members take on such a repair? I'm based in the UK.
Thanks again for the advice
Dom
sonavor
Posts 3,732
sonavor replied on Wed, Aug 9 2017 3:47 PM
I have done both, a substitute cartridge mount from a donor Beogram 400x unit and the Beolover 3D printed replacement. The amount of effort is the same for both. I prefer using the Beolover 3D option (and I am currently about to do that on a Beogram 4002). The reason is I hate to sacrifice a another Beogram turntable just for the cartridge mount.
-sonavor
Page 1 of 1 (4 items) | RSS
