I have bought a Beosound 35 on eBay and I am not able to do a complete factory reset. The Beosound 35 always remember the TuneIn User Account of the old owner. When I do a rest with the menu, the account is still there.
Is there the possibility to perform a complete reset of the Beosound 35 to delete all (Accounts, protocols, etc.)
Thank you for your help.
Mirco
Yes, I have tried this. But the old account is back, after an complete Power OFF / ON.
Thanks.
I have tried it with the menu but this doesn't work.
It is possible to do a "Factory Reset" by:-
User credentials for music services (e.g. TuneIn, Deezer and Spotify) will only be reset if the product is connected to the internet
Regards Keith....
Thanks, but this is what I have tried.
Keith Saunders:User credentials for music services (e.g. TuneIn, Deezer and Spotify) will only be reset if the product is connected to the internet
This means that you have to enter YOUR settings for network first (if connected via WIFI, for your BS35 to be able to access the internet), and then to run the reset process.
It should not be necessary if connected via Ethernet.
Anyway, this process sounds odd to my ears (a factory reset is generaly used because of problems, and it may work whatever you do....)
There's also a reset function on the X app. Did you try it too?
Does the previous user not have to remove the device from their device lists in their Tunein account? Not sure if it is the same as a Digital Radio
Hmm, I tried the above things, but there was no change.
I always gets this error:
