Hello all
Some advice please, I want a tv for my spare room.
Needs to have ML so I can send music to it and the main room picture.
Must be as cheap as possible as it might only get used like once or twice a month
Should be able to control a sky digibox via the stb controller
Widescreen is a preference but not a huge request as CRT is ok too.
Any ideas?
mx7000 is it up to date enought
Mx8000 Any good
I dot really want to spend
Los on a beovision 6
Eclipse 65V1-32Beosound M5Essence MK2BLI
The best of your suggestions may be the MX 8000, as you can change the picture Format (aspect) between 4:3 and 16:9.
The cheapest is the MX 7000 -but the sw is not as up to date. Don't know if it's a problem using stb controller, though...
what´s about BeoVision 3-28? the last one?
BV1 is still a nice cheap little buy :) Even Trevor Nelson has one in his bedroom Seanie!
BV6 is a truly beautiful little unit Seanie if you one get one cheap - I think they are around £600 very very nice sound quality & classy picture if looked at directly.
BV1 or BC1 version with DVD CD and radio are now remarkably cheap. Get one on a tall pole stand (reduced to suit ceiling height if necessary).
It's an iconic piece of B&O and has that great presence when turned off that David Lewis aimed for with all his designs.
Graham
vikinger: BV1 or BC1 version with DVD CD and radio are now remarkably cheap. Get one on a tall pole stand (reduced to suit ceiling height if necessary). It's an iconic piece of B&O and has that great presence when turned off that David Lewis aimed for with all his designs. Graham
Yes -remarkably cheap...I've just bought a BV 1 for 250 DKKr (appr. 25 £) -with that special remote...
i have an Avant fot this very purpose, BL4000 speakers in it i believe, or something close, widescreen and the remote with work a sky box,
andy
Have just replaced my LX6000 with a BV3 - very happy - thank you to Lee and Lifestyle for this!
Peter
Hay there. I have a bv3 in my bedroom but they are far to big.
Needs to be something smaller I think, no bv1's on eBay cheap at the moment but one of those with a ML and STB would be excellent I think.
Would have to agree bv1 or bc1,very unique looking,flexible mounting options,fantastic picture and sound,get a ls model which is masterlink specefic,and you can control or your main room sources.
What about a MX4200?
Has the option to change the picture format (4:3/16:9)
Watch out though, I believe they all have a masterlink socket fitted but not all have the masterlink circuit board. (I remember seeing a previous post about this).
Adrian.
PS I think you're spoiling your guests
