I've recently purchased a beocenter 3500 (my first piece of bang and olufsen kit, ever! Exciting!!) however on the car ride home, the wire inside the lid that allows for the soft-close, has come out of it's place.. I've trawled the Internet and the forums on this site for an answer as to how the wire inside the lid should sit but no luck.
I I would be grateful for any help at all with how the lid and wire inside goes together.
thank you in advance for the help!
Alex
Hi Alex
I have a similar difficulty with the record player lid on my beocenter 7000. The lid has no hold of its own so I have to hold it up with one hand whilst changing a record with the other. There are two clips inside the lid one to the left the other to the right but they are evidently exerting no force. I wonder if something could be tightened somewhere?
Did you find a solution? My local B&O said they could send it offf to see if it could be repaired but I think there is always the risk of transit damage with such a weighty and complex item.
All the best
Jim
