Hi, I bought a Bang & Olufsen dvd 2 from London. I want to use it in the United States, but from my understanding, it doesn't have an ir, so it needs a scart cable to control it. I currently have a beosystem 1, is there anyway for me bypass this maybe a scart to ir cable or something.
-Thanks in advance and GOD Bless
Bump
I am sure you can but you will need a special cable. There are many Scart to component leads but you need one which will attach to the data out of the BS1. I would suggest chatting to Steve at Sounds Heavenly.
Peter
