Hi guys,
We're looking at what features we should bring over from the BeoRemote app to the X app and perhaps you can help. Below is a high level list of what we're considering. Please comment and tell us what you use the most and perhaps how often you use it:
Please add any that I might have missed. Your help is much appreciated!
Br,
Thomas, Bang & Olufsen
Speaker Groups
Sound Modes
Video Modes
The basics:
Volume
On/Off
(so... the functionality of the Essence Remote)
Additional:
Source
Karel.
Hi
It would be nice if it was possible to hide sources that is not in use, in the BeoRemote app I can see all 5 HDMI inputs even though only one is used.
Søren
1. Number keypad
2. Stop / Play / Pause
3. Programme up / down
Thank for reaching out.
SB
Hej Thomas,
if you by 'Source selection' e.g. mean selecting (your) netradio stations by clicking a Radio icon without having to navigate through several submenus to get to the favourite list of TuneIn - then yes, high priority!
And please make it possible to access Radio stations with the number key on a remote - for those of us, who use the physical remote/s.
And please make it possible to remove the sources, one does not want to see.
Respectively to edit the priority of the sources - the linked ones included.
'My buttons' - that would be great!
You did not mention 'Grouping' of devices to play/control - but I guess that is part of the intended features - is that perhaps, what you mean with 'Expand'?
Personally I would prefer to give a 'search field' in Deezer priority over anything else in that source - but that probably wiill remain wishfull thinking ;-(
Possibility to edit the order/priority of the DLNA servers reachable.
That is what comes into my mind right now.
P.S. Don't forget the iPad version - I guess a lot of users want to control their setup using a bigger display.
+1 for Speaker Groups.....
MrAndersen:Hi guys, We're looking at what features we should bring over from the BeoRemote app to the X app and perhaps you can help. Below is a high level list of what we're considering. Please comment and tell us what you use the most and perhaps how often you use it: Source selection On/Off Volume My Buttons Mute/Unmute Up/Down/Left/Right navigation Join/Expand Please add any that I might have missed. Your help is much appreciated! Br, Thomas, Bang & Olufsen
mjmedlo:I think favorites is nice too. Some of my video favorites are audio only and that would be nice to be easily accessed.
Regards
Kiran
Born in NL; I ride ML
my humble suggestions
-stand
-picture on/off
-generally the same level of integration for Apple Music as it is for Deezer etc.
thanx alot 😘
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound + appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
If it possible, to see the EPG is a great feature. My old LOEWE TV shows the Channel List of the TV an the EPG on the app. Very cool...
Thank you guys for the feedback, much appreciated.
@mjmedlo: When you say favorites could you elaborate? Is this my buttons?
@Millemissen: Your wishes on radio i don't quite get. We can only select a source for example radio and then change the station? When i say expand i mean expand the sound to the TV from another speaker, join is for example playing TV sound from a speaker in a different room
sorry - I was thinking 'Beomusic app' all the time.
Therefore my concern about hangling through several menus to get to TuneIn and to my presets.
Maybe I should rewrite my post - this time actually having the BeoRemote app in mind.
Sorry again ;-(
+1 for the NL/ML Converter
akoitidis:+1 for the NL/ML Converter
Please add HOME CONTROL so the BLGW can be accessed on NL TVs.
Thank you.
