Beolab 5 shots
This post has 46 Replies | 2 Followers
Beobuddy
Utrecht, The Netherlands
Posts 3,972
This can't be seen as a reference.
Things has changed during the past years.
Prizes differ from which chassis the BL5 has.
The latest mk3 doesn't have an eeprom, which can't be transferred to the a new chassis. That has to be done with B&O's servicetool.
pauljrog
Posts 92
Just wanted to ask from what serial no does the mk3 start??
Sweden
Posts 357
Silver Member
Martin replied on Sat, Oct 6 2018 7:22 AM
Hi Beobuddy,
I have Beolab 5 from May 2015 with serial number that starts with 244xxxx. I have recently changed mainchassi in one of my speakers. This chassi still has eprom memory that has to be switched to the new chassi. I don’t think B&O make a change in a product so late in a product cycle that Beolab 5 was in 2016 and 2017.
Best Regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
L1NO
Posts 250
L1NO replied on Sat, Oct 6 2018 8:05 AM
Heared these noises with my BL12 and turned out to be bad cable. I’ve heared ‘computer’ noises or ‘remote’ signals trough the earth of my V1. A correct cable sorted my problem.
Beobuddy
Posts 3,972
Martin:
Hi Beobuddy,
Best Regards
I've had 3 BL5's over the past few weeks. 2x mk1 with the small interchangeable eprom and 1 mk3 (sn 239xx ) without the small DIP 8 pins IC.
I noticed some differences on the microprocessor-boards on the inside where the some form of glue was placed on top of some parts.
Sweden
Posts 357
Silver Member
Martin replied on Sun, Oct 7 2018 7:44 AM
Hi, strange that my Beolab 5 with serial number 244xxx still has the eprom IC!. Do you have a clue why?
If yours with serial 239xxx don’t have it then mine should not either have it.
sk0rpion
Posts 3
sk0rpion replied on Fri, Dec 13 2019 1:42 PM
Hi ESBOSS, did you figure out the problem? I have same issue with one of my speaker.. https://www.youtube.com/watch?v=_-FZp7MfxA4
Page 2 of 2 (47 items) < Previous 1 2 | RSS
