Beolab 5's inherited
This post has 10 Replies | 1 Follower
michaelsch
Posts 1
michaelsch Posted: Sun, Apr 30 2017 12:05 AM
I am located in the Boston area and just inherited Beolab 5 speakers. Do I need an amplifier to run?
Thank you.
thunder
Posts 28
thunder replied on Sun, Apr 30 2017 1:27 AM
No. BeoLab5's have amplifiers built into them. You'll need either a special "powerlink"* cable, usually used with B&O equipment, regular line-in or I believe a toslink input.
Count yourself very lucky on inheriting these speakers. They are gems.
 * Inaccurately name because no actual power is transmitted via these cables. Just audio signals.
h1npw
West Bridgford, Nottingham.
Posts 1,130
h1npw replied on Sun, Apr 30 2017 7:31 AM
"very lucky"...... Must qualify for the Understatement of the Year award!
Kiran
UK
Posts 1,023
Kiran replied on Sun, Apr 30 2017 7:56 AM
michaelsch:
Thank you.
You lucky sod!
Those tanks run by themselves 👍🏻👍🏻
No amp required 🙂
Regards
Kiran
Born in NL; I ride ML
CB
> You are Here <
Posts 1,762
CB replied on Sun, Apr 30 2017 8:06 AM
Hi and welcome to Beoworld !
Consider the BL5s as a set of an integrated amplifier + signal converter + loudspeaker. All you need is an audio signal (analog or digital) and (may be) a B&O remote (to start/stop and set the volume level).
thunder:
To be accurate, the digital BL5s connection is S/PDIF (Sony/Philips Digital Interface Format) ; not with fiber optic cable with Toslink connectors but 75 Ohms coaxial cable with RCA connectors.
For the comparison, Powerlink and Line-in use analog and electrical signals.
Geoff Martin
Struer, Denmark
Posts 672
I have seen one case where a person fed their BeoLab 5's using the power amp outputs of a third-party receiver using home-made adapters with RCA plugs on one end  (for the BL5's) and bare wire on the other end (for the amp outputs on the receiver).
This is a bad idea. Do not do this. Use a line output - not a power amp output - if you connect the line input of the 5's to a non-B&O device.
Cheers
-geoff
Millemissen
Flensborg, Denmark
Posts 14,680
michaelsch:
Thank you.
This may answer that and most of your questions concerning how to use the BL5's.
If you have any further, feel free to ask these here.
Congrats on the BL5's and welcome to Beoworld.
Millemissen
Flensborg, Denmark
Posts 14,680
Oups, sorry - here is the link ;-(
http://www.bang-olufsen.com/~/mediaV3/Files/User-Guides/BeoLab5/EN-BeoLab5.pdf
Dante
Sao Paulo - Brazil
Posts 163
Dante replied on Mon, May 1 2017 2:19 PM
You'll also need a remote control from B&O to operate those speakers when using line-in or toslink inputs.
Michael
Sweden
Posts 2,578
Michael replied on Mon, May 1 2017 2:56 PM
michaelsch:
Thank you.
Congratulations, they are amongst the very best speakers ever produced. Considering their size and design I would say the best ones ever produced. While also being easy to operate. Not many things like that on the market.
I hope you will enjoy them a lot!
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi michaelsch,
I think everyone who reads this post is very envious of you - I can confidently speak for most Beoworlders when I say that Beolab 5s are on almost all of our wishlists! Big Smile
you can use these superb speaker with almost any audio or video product, the main caveat (as Geoff mentioned previously) is not to try connecting them to the speaker terminals of a power amplifier, as this can cause very expensive damage.
If you can please tell us which devices you use to play your music and movies, we can help you use these to best effect with your new speakers.  The more detail you can give us about the equipment you have, the better placed we will be to help!
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (11 items) | RSS
